Home » Eclipse Projects » Eclipse Platform » Is there an auto-indent/format feature for *.xml files in Eclipse?
Is there an auto-indent/format feature for *.xml files in Eclipse? [message #332236] Mon, 13 October 2008 21:14 Go to next message
Originally posted by: under.lycos.co.uk
For an existing project I created a XML file and pasted
some XML code into it.
However all lines in this code start at the first column.
Is there a format/auto-indent/beautifier feature which indents
every XML level by say 3 (more) blanks?
Jeff
Re: Is there an auto-indent/format feature for *.xml files in Eclipse? [message #332349 is a reply to message #332236] Mon, 20 October 2008 10:28 Go to previous message
Jeff,
I'm noticing quite a few posts from last week that are cross posted to
multiple groups but have a "followup-to" that results in replies going
only to that group. Your's is one of such posts. How did you post it
so that it ended up with a "followup-to"? It's a bit annoying because
it means that only the one group will get a reply and hence the other
group will look not to have replied at all...
> Jeff
Previous Topic:How to auto-create for import the folders from java package?
Next Topic:WTP plugin for Eclipse 3.3.2 needs (but can not!) download GEF version v3.4 ? Solution?
Current Time: Sun Feb 09 16:45:49 GMT 2025
Powered by FUDForum. Page generated in 0.03724 seconds
