Re: Unsupported Type during Deploying [message #1761107 is a reply to message #1761083] |
Sat, 06 May 2017 21:22 |
I'm sorry that 4diac is giving you such a hard time. If you get an UNSUPPORTED_TYPE error this definitely means that the forte.exe you have started has not your FB compiled into. What I noticed with VS is that sometimes when i add new modules in cmake or add a new FB to a cmake list file that the when building in VS that the FB is not compiled. you can see this when watching the build output and your FB is not listed as cpp file to be compiled. What worked for me in this case is to run CMake GUI again with configure and generate.
Maybe it will be interesting for you that Monika just merged a branch into the main development branch where you don't need to compile your FBs. this will be part of the upcoming 1.9.0 release.
FUDForum. Page generated in 0.02806 seconds
