Home » Language IDEs » Andmore » Imported C++ registered package issue
Imported C++ registered package issue [message #1760972] Thu, 04 May 2017 15:08 Go to next message
I imported the C++ STL registered package into a project and added a property, s, of type string to a class. Then I generated the code.
The generated .h file contains this:
class myHelloWorldClass {
public:
	string s;
	void run();
The problem is that the type should be "std::string" instead of just "string" so the code will not compile as is.
The workaround is to add "using namespace std;" to the header but this should not be necessary. Is there another way?
I understand that this library is still a work in progress and the bugzilla improvement issue https://bugs.eclipse.org/bugs/show_bug.cgi?id=496934 is still in the NEW state.
Also I would like to help fix this and work on the STL package if someone will point me in the right direction.
Steve
PS This is with version 2.0.3.201703080851.
Re: Imported C++ registered package issue [message #1760973 is a reply to message #1760972] Thu, 04 May 2017 15:26 Go to previous message
Oops, wrong forum!!
Previous Topic:Can't open Eclipse after computer crash
Next Topic:OpaqueBehavior editor issues
Current Time: Mon Mar 24 06:03:06 EDT 2025
Powered by FUDForum. Page generated in 0.03750 seconds
