Home » Eclipse Projects » Eclipse Platform » Resource synchronize problem
Resource synchronize problem [message #331879] Fri, 26 September 2008 11:01 Go to next message
If i rename a file in an eclipse project outside the workspace then i am
not getting MOVED_FROM or MOVED_TO flags from ResourceDelta.
Rather eclipse platfrom sends ADD of New file (with new name) and DELETE
of old file.
Do i need to implement any extension point to provide my own
implementation of computing change deltas for IResources (files, folder)
while synchronizing workspace file with local file system.
Re: Resource synchronize problem [message #331880 is a reply to message #331879] Fri, 26 September 2008 11:03 Go to previous messageGo to next message
To make it clearer, I am renaming the file not from eclipse but outside
eclipse directly from file system
Re: Resource synchronize problem [message #331881 is a reply to message #331880] Fri, 26 September 2008 11:47 Go to previous message
Don't do that! :-P Files don't have identity. Well, maybe they have
inodes on linux, I don't know if that would help. But generally they
don't have identity so there is no way for Eclipse to know you didn't
delete the file and create a new file. The user might have even done a
copy, followed by a delete to achieve their desired affect, so you're
not going to be able to rely on MOVE information if you aren't using the
Eclipse APIs to move the files.
> outside eclipse directly from file system
Previous Topic:Link with editor
Next Topic:new debugger implementation - changing default names
Current Time: Sun Feb 09 19:21:18 GMT 2025
Powered by FUDForum. Page generated in 0.03325 seconds
