Home » Eclipse Projects » Eclipse Platform » Extending DeleteResourceAction
Extending DeleteResourceAction [message #331859] Thu, 25 September 2008 13:58 Go to next message
Originally posted by: andreas-scharf.gmx.de
I have view using the CNF which currently does almost the same as the
Resource Explorer. In my special application I have dependent resources
and if the user deletes resource A the dependent resource B (which is a
file which only contains UI information) also should be deleted. I
thought of using my own MyDeleteResourceAction in which I execute 2
DeleteResourceActions (one to actually delete the resource the user
selected and one to delete the dependent UI information resource).
Is that approach applicable or is there another (better) way to do this?
Greetings,
Andreas
Re: Extending DeleteResourceAction [message #331869 is a reply to message #331859] Thu, 25 September 2008 18:35 Go to previous messageGo to next message
Check out adding an LTK delete participant, which in 3.4 the Package
Explorer, Project Explorer and Resource navigator will honour.
PW
Paul Webster
Re: Extending DeleteResourceAction [message #331878 is a reply to message #331869] Fri, 26 September 2008 09:19 Go to previous messageGo to next message
Paul,
thanks for pointing me to the ltk (never heard about that before). I'll
check this out.
Andreas
> PW
Re: Extending DeleteResourceAction [message #331900 is a reply to message #331878] Sat, 27 September 2008 10:18 Go to previous messageGo to next message
Paul,
I implemented extending the DeleteResourceAction using the ltk stuff.
But I've got some question about the correct implementation of a
participant. One of my participants also deletes a corresponding file
which contains UI related information about the file the user wants to
delete. Now what happens is, when the user e.g. selects A.file AND
A.fileUI my participant should not add a Change. I've implemented it
checking in the createChange() method if getProcessor().getElements()
already contains the element my participant wants to delete. Now the
question is if this is the right place to do it. Or is there another
mechanism to not add a second change to delete the resource?
Andreas
Andreas Scharf schrieb:
> Paul,
> check this out.
> Andreas
>> PW
Re: Extending DeleteResourceAction [message #332002 is a reply to message #331900] Wed, 01 October 2008 13:14 Go to previous message
Andreas Scharf wrote:
> Paul,
Unfortunately my knowledge of LTK is limited. Hopefully someone else
can answer ... you could also ask your LTK question on eclipse.tools.jdt
PW
Paul Webster
Previous Topic:How to disable Welcome view when running/debugging eclipse plug-in
Next Topic:unable to uninstall plugin with p2
Current Time: Tue Feb 11 00:06:34 GMT 2025
Powered by FUDForum. Page generated in 0.03631 seconds
