Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » ANY not compatible with ANY(connect data: any with any)
ANY not compatible with ANY [message #1756273] Tue, 14 March 2017 18:53 Go to next message
Ernst Murnleitner is currently offline Ernst MurnleitnerFriend
I wanted to echo back data received. If I connect the RD1 of SUBSCRIBE1 with SD of PUBLISH1, this is not possible. "ANY not compatible with ANY" is displayed.
Is this correct behaviour?
Re: ANY not compatible with ANY [message #1756279 is a reply to message #1756273] Tue, 14 March 2017 21:38 Go to previous message
Alois Zoitl is currently offline Alois ZoitlFriend
Unfortunately currently yes. The problem is that most layers currently will check if the incoming data is suitable for the data output. Therefore you currently have to explicitly type the interface by adding some intermediate FB which gives both sides a type.
Previous Topic:RPi3 IX & QX error
Next Topic:Server disconection
Current Time: Wed Feb 21 08:12:29 GMT 2018
Powered by FUDForum. Page generated in 0.01528 seconds
