Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Analog IO Expansion Board
Analog IO Expansion Board [message #1755473] Fri, 03 March 2017 15:11 Go to next message
Jonathan Swarts is currently offline Jonathan SwartsFriend
I was wondering if there's an IO expansion board for analog input and output for a simple solution that is compatible with 4DIAC. Also, something that's preferably located in the US.
Jonathan
Re: Analog IO Expansion Board [message #1755699 is a reply to message #1755473] Mon, 06 March 2017 20:53 Go to previous message
Alois Zoitl is currently offline Alois ZoitlFriend
this depends a bit on what controller you are using. I would say in general the IOs for the Wago PFC200 are the best support I/Os we currently have. Wago also sells in the US and they have a wide variety of IO modules so this could be an option.
If you are looking for Raspberry PI or BeagleBone Black extension boards then it will get harder. RaspberryPI SPS [1] or Conmeleon [2] have analogue IOs with the upcoming 1.9.0 release we will add support for the EMBrick Modules[1] which feature a wide set of different modules, but I'm not sure if you can get any of these in the US.
However if anyone has a suggestion for modules we are happy to add this to 4diac.
Alois
[1] http://raspberry-sps.de/
[2] http://www.conmeleon.org/
[3] http://www.embrick.de/partner/
Previous Topic:New composite type
Next Topic:ANY not compatible with ANY
Current Time: Tue Aug 21 19:38:36 GMT 2018
Powered by FUDForum. Page generated in 0.01237 seconds
