Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Raspberry SPS build
Raspberry SPS build [message #1752712] Thu, 26 January 2017 12:24 Go to next message
Yernar Nukezhanov is currently offline Yernar NukezhanovFriend
I am trying to build forte for Raspberry SPS. I followed as in the tutorial but still am getting errors. What could be the problem?
Thank you
index.php/fa/28234/0/
  • Attachment: Error.png
    (Size: 51.92KB, Downloaded 183 times)
Re: Raspberry SPS build [message #1752804 is a reply to message #1752712] Fri, 27 January 2017 13:59 Go to previous messageGo to next message
Alois Zoitl is currently offline Alois ZoitlFriend
this is strange. It looks as there is some issue with your cross compiler. Could you be so kind and post the full output of CMake into a text file and attach it here?
BTW. I just saw that you selected the wrong directory for the "Where is the source code" it should be the main FORTE directory. In your case C:/org.eclipse.4diac.forte.
BR,
Alois
Re: Raspberry SPS build [message #1752807 is a reply to message #1752804] Fri, 27 January 2017 14:20 Go to previous messageGo to next message
I suspect that it is some kind of compatibility problem, but unfortunately I was not able to fix it.
I have 64bit Windows and have used following Linaro toolchain:
https://releases.linaro.org/components/toolchain/binaries/latest/arm-linux-gnueabihf/
gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf.tar.xz
  • Attachment: Error.txt
    (Size: 1.55KB, Downloaded 35 times)
  • Attachment: CMakeError.log
    (Size: 2.30KB, Downloaded 40 times)
Re: Raspberry SPS build [message #1752813 is a reply to message #1752807] Fri, 27 January 2017 15:13 Go to previous messageGo to next message
Kirill Dorofeev is currently offline Kirill DorofeevFriend
Member
hi, as far as i can see, you're trying to run linux compiler on windows. please, download the mingw32 toolchain from https://releases.linaro.org/components/toolchain/binaries/6.1-2016.08/arm-linux-gnueabihf/gcc-linaro-6.1.1-2016.08-i686-mingw32_arm-linux-gnueabihf.tar.xz
the other issue might be that you should unpack the archive as administrator, otherwise it might prevent creation of symbolic links.
hope, this will work for you.
[Updated on: Fri, 27 January 2017 15:15]
Report message to a moderator
Re: Raspberry SPS build [message #1752883 is a reply to message #1752813] Mon, 30 January 2017 10:14 Go to previous messageGo to next message
Thank you for reply. It helped a lot.
The one thing also to mention is to run all programs as adminstrator (cmake, gcc, g++).
During configuring in cmake I got two red lines. In tutorial it says that there shouldn't be any of them, but if I check them some errors appear during make. I left them unchecked and it worked well, I hope it will run properly in Raspberry SPS as well.
index.php/fa/28263/0/
  • Attachment: Cmake.png
    (Size: 41.30KB, Downloaded 154 times)
Re: Raspberry SPS build [message #1752934 is a reply to message #1752883] Mon, 30 January 2017 22:33 Go to previous message
The read lines are perfectly ok. They are coming as with checking some modules or architectures it can be that new options are getting available. Therefore you can find in the documentation that you should hit configure as long as you don't get new red lines and then finally generate.
Previous Topic:Java heap space Problem
Next Topic:BOOL to ANY_BIT converstion (IEC61131-3 Bitwise Operators)
Current Time: Wed May 23 14:50:03 GMT 2018
Powered by FUDForum. Page generated in 0.01931 seconds
