Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » FORTE 1.8.3 cannot be built on Raspbian Jessie
FORTE 1.8.3 cannot be built on Raspbian Jessie [message #1751812] Sat, 14 January 2017 18:02 Go to next message
Manuel Parfant is currently offline Manuel ParfantFriend
Good evening,
I can't build FORTE 1.8.3 on the Raspberry Pi, running Raspbian Jessie. FORTE 1.8.2 and older can be built without problems.
The build operation hangs at 50% with the following output:
[ 49%] Generating src_gen/GEN_PUBL_gen.cpp
Scanning dependencies of target forte_stringlist_externals
[ 50%] Linking CXX static library libforte_stringlist_externals.a
[ 50%] Built target forte_stringlist_externals
Scanning dependencies of target forte_generate_modules_cmake_files
After canceling the operation with ctrl+c, the following messages appear:
^Csrc/CMakeFiles/forte_generate_modules_cmake_files.dir/build.make:57: recipe for target 'src/CMakeFiles/forte_generate_modules_cmake_files' failed
make[2]: *** [src/CMakeFiles/forte_generate_modules_cmake_files] Interrupt
CMakeFiles/Makefile2:167: recipe for target 'src/CMakeFiles/forte_generate_modules_cmake_files.dir/all' failed
make[1]: *** [src/CMakeFiles/forte_generate_modules_cmake_files.dir/all] Interrupt
Makefile:127: recipe for target 'all' failed
make: *** [all] Interrupt
Any idea what could be wrong?
Re: FORTE 1.8.3 cannot be built on Raspbian Jessie [message #1751814 is a reply to message #1751812] Sat, 14 January 2017 20:17 Go to previous messageGo to next message
Alois Zoitl is currently offline Alois ZoitlFriend
I fear that this is the same issue as reported in this bug. I've fixed it already. So if you check out the latest version from the 1.8.x branch from our git repo this issue should be gone.
Sorry for the inconvenience.
Re: FORTE 1.8.3 cannot be built on Raspbian Jessie [message #1751817 is a reply to message #1751814] Sat, 14 January 2017 20:38 Go to previous messageGo to next message
Hi Alois,
thank you for your quick reply.
You are right, that was the problem. Now it works Wink.
Wish you a nice weekend.
[Updated on: Sat, 14 January 2017 20:39]
Report message to a moderator
Re: FORTE 1.8.3 cannot be built on Raspbian Jessie [message #1751818 is a reply to message #1751817] Sat, 14 January 2017 20:40 Go to previous message
You are welcome.
Previous Topic:Version Information on Splash Screen
Next Topic:Downloading boot file using IEC 61499 Deployment Plug In
Current Time: Fri Oct 19 23:56:55 GMT 2018
Powered by FUDForum. Page generated in 0.01918 seconds
