Home » Eclipse Projects » P2 » Signing jars for Eclipse 3.6.x or higher(What are the correct arguments for jarsign in order to be able to install signed plugins on Eclipse 3.6 or higher)
Signing jars for Eclipse 3.6.x or higher [message #1740246] Wed, 10 August 2016 13:07 Go to next message
Hello to the forum members,
I'm developing a plugin for an Eclipse product. It has two instances, one supports Eclipse 3.6.x and the other 4.2.x. I'm using signjar ant task to sign my plugin and feature. When I try to install it on Eclipse I keep getting "Error reading signed content" error. Doing some digging in Eclipse source and on the web I found the following links:
https://dev.eclipse.org/mhonarc/lists/cross-project-issues-dev/msg11770.html
https://bugs.eclipse.org/bugs/show_bug.cgi?id=378155
So, I understand there's an issue with Eclipse 3.6 and signing jars with Java 1.7. I'm using IBM Java 1.6 and I still get this error.
By the way the signjar task outputs the following:
[signjar] Warning:
[signjar] Using SHA-1 digest algorithm for timestamp generation. See the -tsadigestalg option.
Any ideas how to fix this ?
Gidi
Re: Signing jars for Eclipse 3.6.x or higher [message #1740317 is a reply to message #1740246] Thu, 11 August 2016 10:20 Go to previous message
An update: I found out that a work-around would be to perform the signing process with Java 1.5 and Eclipse 3.5. I'm still looking for a solution, preferably for Java 1.7.
Also, the link below describes work-around of setting the signatures on the update site instead of the jars. If anyone has a link that explains this process and whether it requires changes in workflow for the user, I'll be grateful if you could share it here.
Gidi
[Updated on: Thu, 11 August 2016 14:14] by Moderator
Previous Topic:How to set system environment variable eclipse configuration file?
Next Topic:P2 updating root files on Mac replaces product executable, losing executable permission
Current Time: Sun Jun 22 11:39:41 EDT 2025
Powered by FUDForum. Page generated in 0.08479 seconds
