Home » Eclipse Projects » Sirius » tutorial: graphical designer test not working
tutorial: graphical designer test not working [message #1739792] Wed, 06 November 2013 08:13 Go to next message
sninja sninja is currently offline sninja sninjaFriend
Member
Greetings,
I'm going through Sirius basic family starter tutorial and everything worked out fine, until graphical designer test part. I did every step like it is in tutorial, but in runtime my designer doesn't show sample domain model elements (mother, father, two children) and create new person does nothing when I choose it from palette.
What could be the problem? I went through tutorial several times and no luck. I've even tried Obeo demo designer and it's working, but my Sirius project would not. I wrote earlier on another topic about org.eclipse.sirius.common.acceleo.mtl bundle problem. Maybe that has something to do with it? Maybe project can't see Acceleo expresions...
So, any ideas?
Thank's.
Re: tutorial: graphical designer test not working [message #1739794 is a reply to message #1739792] Thu, 07 November 2013 08:24 Go to previous message
Alex Lagarde is currently offline Alex LagardeFriend
yes maybe this is related to the issue you mentionned in your previous
post. Could you launch a validation of your VSM (.odesign file) by
righ-click on an element and select the "Validate..." action?
Alex
Re: tutorial: graphical designer test not working [message #1742033 is a reply to message #1739792] Thu, 07 November 2013 08:24 Go to previous message
Alex
Previous Topic:bundle org.eclipse.sirius.common.acceleo.mtl cannot be resolved
Next Topic:bundle org.eclipse.sirius.common.acceleo.mtl cannot be resolved
Current Time: Fri Apr 16 15:37:14 GMT 2021
Powered by FUDForum. Page generated in 0.02293 seconds
