Home » Eclipse Projects » e(fx)clipse » install problems
install problems [message #1739767] Thu, 08 August 2013 12:31 Go to next message
Enrico R. is currently offline Enrico R.Friend
Member
I try to install efxclipse 0.8.1 into Kepler (4.3.0 I20130605-2000) but i still get these errors:
Cannot complete the install because one or more required items could not be found.
Software being installed: e(fx)clipse - All in One 0.8.1.201303200240 (at.bestsolution.efxclipse.feature.feature.group 0.8.1.201303200240)
Missing requirement: Jemmy 0.8.1.201303112105 (at.bestsolution.efxclipse.runtime.jemmy 0.8.1.201303112105) requires 'bundle org.junit4 4.8.1' but it could not be found
Missing requirement: Jemmy 0.8.1.201303200240 (at.bestsolution.efxclipse.runtime.jemmy 0.8.1.201303200240) requires 'bundle org.junit4 4.8.1' but it could not be found
Cannot satisfy dependency:
From: e(fx)clipse - All in One 0.8.1.201303200240 (at.bestsolution.efxclipse.feature.feature.group 0.8.1.201303200240)
To: at.bestsolution.efxclipse.tooling.feature.feature.group [0.8.1.201303200240]
From: e(fx)clipse - Jemmy FX to Junit Test OSGi-Apps 0.8.1.201303112105 (at.bestsolution.efxclipse.runtime.jemmy.junit.feature.feature.group 0.8.1.201303112105)
To: at.bestsolution.efxclipse.runtime.jemmy [0.8.1.201303112105]
From: e(fx)clipse - Jemmy FX to Junit Test OSGi-Apps 0.8.1.201303200240 (at.bestsolution.efxclipse.runtime.jemmy.junit.feature.feature.group 0.8.1.201303200240)
To: at.bestsolution.efxclipse.runtime.jemmy [0.8.1.201303200240]
From: e(fx)clipse - Composite - FX Tooling 0.8.1.201303200240 (at.bestsolution.efxclipse.tooling.feature.feature.group 0.8.1.201303200240)
To: at.bestsolution.efxclipse.runtime.jemmy.junit.feature.feature.group 0.8.1
Running Kepler (64Bit) on Win7 (64Bit) with JDK 1.7u25 (64Bit) and I used these update sites:
http://www.efxclipse.org/p2-repos/nightly/site/
http://downloads.efxclipse.org/p2-repos/releases/latest/
both with same results.
I also tried to install only "e(fx)clipse - Composite - FX Tooling 0.8.1.201303112105" but it ended in the same result.
Is there something broken? Should I use other update sites?
I appreciate any help.
Thanks...
Re: install problems [message #1739768 is a reply to message #1739767] Thu, 08 August 2013 14:51 Go to previous message
Thomas Schindl is currently offline Thomas SchindlFriend
For Kepler install please use
http://download.eclipse.org/efxclipse/updates-nightly/site and if you
want to setup a target use
http://download.eclipse.org/efxclipse/runtime-nightly/site
Tom
On 08.08.13 14:31, Enrico R. wrote:
> Hello,
> be found.
> 0.8.1.201303112105
> 0.8.1.201303112105)
> 0.8.1.201303200240
> 0.8.1.201303200240)
> 0.8.1.201303200240)
> To:
> Thanks...
Previous Topic:Re: application doesn't start anymore
Next Topic:Install missing dependencies
Current Time: Fri May 29 21:25:44 GMT 2020
Powered by FUDForum. Page generated in 0.01416 seconds
