Is it possible that the mn-cse running alone without registering to in-cse? [message #1739473] |
Tue, 02 August 2016 08:52  |
Son Duong Messages: 60 Registered: June 2016 |
Member |
Hi all,
I know that OM2M contains two main components: the in-cse for infrastructure node and mn-cse for middle node. Sometime I am a little bit confused how the flow in OM2M works? Firstly, the mn-cse must register to in-cse then they can communicate together. In this case, if I have an application deployed in mn-cse and when it sends request to its deployed cse (mn-cse), does this request directly fly to the mn-cse or first to in-cse and will be forwarded to the corresponding mn-cse? I mean, in the case if we have 1 in-cse and 1 mn-cse registered together, does that request always first come to the in-cse ? If so, then the in-cse will always act like the server, is it right?
In other case, if I would like to run a system without the server, peer to peer for example, can I run only the mn-cse without the in-cse? I tried to start only the mn-cse but the osgi console showed that the mn-cse must first be registered to the in-cse (Error in registration to another CSE....).
Thank you so much
[Updated on: Tue, 02 August 2016 09:25] Report message to a moderator
FUDForum. Page generated in 0.01985 seconds
