Re: New distribuited Application Problem [message #1738999 is a reply to message #1738997] |
Tue, 26 July 2016 16:35 |
in principal the steps are the same as in the example with the remote frame. As you did already correctly you configured the MGR_ID of your two devices to the correct IP address and port. The next step is to map your application parts to resources in the two devices. Afterwards you need to insert communication function blocks into the resources which will handle the communication between the two devices. I think this is also covered in this example.
Alois
P.S.: If you are keen you can also test a beta feature of 4diac: There is the possibility to automatically generate the communication function blocks. Right click on your application in the System Explorer and select Generate ... -> Generate communication FBs. But as said this feature is beta!!! Save your project and backup it before you try it.
Re: New distribuited Application Problem [message #1739010 is a reply to message #1739006] |
Tue, 26 July 2016 18:40 |
You have to thank Luka Ledniki who implemented it.
You can freely map your function blocks according to your needs. So if your application requires you can even map all except one FB to one device and the other one to the other device. The only restriction may be the amount of memory you have available on your devices.
FUDForum. Page generated in 0.03377 seconds
