Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Use STRING datatype with IEC61131 F_SEL block
Use STRING datatype with IEC61131 F_SEL block [message #1733888] Wed, 01 June 2016 20:36 Go to next message
Herwig Eichler is currently offline Herwig EichlerFriend
I'd like to switch between two string constants, depending on a BOOL value. That's why the F_SEL block was my first guess. Both inputs are of datatype ANY so i thought i can connect a STRING there. When I try to enter the string constants directly in the F_SEL properties, the IDE tells me, that this is not allowed. Also connecting other FB with STRING outputs to the F_SEL does not work.
Is there any easy way to achieve this, without having to create my own F_SEL_STRING block and compile it into FORTE?
Herwig
Re: Use STRING datatype with IEC61131 F_SEL block [message #1733893 is a reply to message #1733888] Wed, 01 June 2016 21:36 Go to previous messageGo to next message
Alois Zoitl is currently offline Alois ZoitlFriend
HI,
could you be more specific on the error message. You should be able to put string constants on F_SEL. However as it is an ANY input you have to add the type information to your constants following the IEC 61131-3 literal conventions. For strings this means that you have to add STRING# upfront (e.g, STRING#MYSTRingconstant).
Also connecting strings should work. Could you say more on what is not working there?
Alois
Re: Use STRING datatype with IEC61131 F_SEL block [message #1733912 is a reply to message #1733893] Thu, 02 June 2016 07:55 Go to previous messageGo to next message
Hi Alois,
thanks for your feedback. I did not use the STRING#, so this explains why i was not able to set the string constant in the F_SEL directly. I will try this on the weekend. When trying to connect the output of a CONCAT block with the F_SEL input I see a small prohibition sign and the wire is not connected and disappears when i release the mouse button.
greetings
Herwig
Re: Use STRING datatype with IEC61131 F_SEL block [message #1733936 is a reply to message #1733912] Thu, 02 June 2016 10:39 Go to previous messageGo to next message
Hi Herwig,
thanks for the clarification. The problem with the CONCAT block is that it has as in and outputs ANY_STRINGS which have to be typed as well. Unfortunately we are currently not very good in propagating the type through a network. So for now you would need to insert a STRING2STRING FB between CONCAT and F_SEL. I know this is ugly and I really want to have this gone.
The CONCAT function is maybe better used in algorithms there I think it will also be more efficient as the compiler can optimize away some overhead.
Alois
Re: Use STRING datatype with IEC61131 F_SEL block [message #1734136 is a reply to message #1733936] Sat, 04 June 2016 18:23 Go to previous messageGo to next message
Hi Alois,
the string constant STRING#MyString works now.
I cannot find a STRING2STRING block in the library, at least it is not part of the IEC61131-3 conversion blocks. I can find a STRING_TO_WSTRING converter
kind regards
Herwig
Re: Use STRING datatype with IEC61131 F_SEL block [message #1734185 is a reply to message #1734136] Sun, 05 June 2016 21:32 Go to previous messageGo to next message
STRING2STRING is in the conversion library (Edit: which is outside of the IEC 61131-3 lib).
Alois
[Updated on: Sun, 05 June 2016 21:32]
Report message to a moderator
Re: Use STRING datatype with IEC61131 F_SEL block [message #1734284 is a reply to message #1734185] Mon, 06 June 2016 18:18 Go to previous message
Thanks, Alois
it's working now, I overlooked the "convert" folder in the type library Embarrassed and only searched within the IEC61131-3 converters.
The STRING2STRING after the F_SEL did the trick.
greetings
Herwig
Previous Topic:No trace info in Debug mode in 4DIAC-IDE
Next Topic:BeagleBoard-X15
Current Time: Fri May 25 19:00:47 GMT 2018
Powered by FUDForum. Page generated in 0.01869 seconds
