Home » Eclipse Projects » Eclipse Platform » TableViewerEditor doesn't work under Eclipse 3.4
TableViewerEditor doesn't work under Eclipse 3.4 [message #329525] Fri, 27 June 2008 02:25 Go to next message
I have tried this snippet under Eclipse 3.4 runtime:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse
JFace
Snippets/org/eclipse/jface/snippets/viewers/Snippet025TabEdi ting.java?view=markup
and I cannot edit anything. :-(
Is this a bug?
Any workaround?
Re: TableViewerEditor doesn't work under Eclipse 3.4 [message #329527 is a reply to message #329525] Fri, 27 June 2008 03:09 Go to previous messageGo to next message
What is not working? You noticed that only the items with an even number
are editable?
For the snippet works as expected on Win32 and OS-X.
Tom
David Perez schrieb:
> JFace
> Is this a bug?
> Any workaround?
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: TableViewerEditor doesn't work under Eclipse 3.4 [message #329529 is a reply to message #329527] Fri, 27 June 2008 04:23 Go to previous message
You are right. Thanks to Murphy law I had tried even rows.
Sorry for the noise.
> are editable?
> Tom
Previous Topic:TabbedPropertyList
Next Topic:Failed to prepare partial IU: [R]
Current Time: Tue Jul 22 15:39:17 EDT 2025
Powered by FUDForum. Page generated in 0.04671 seconds
