Home » Modeling » TMF (Xtext) » Problem by reference in Xtext
Problem by reference in Xtext [message #1730853] Fri, 29 April 2016 09:42 Go to next message
Lafleur du versaille is currently offline Lafleur du versailleFriend
Member
hello
how is it possible to get all the values of the Elemet in 'result'.
because I have an error at the editor in result.
how can I have only at 'result', name of the elements that are use to 'Element'.
Thanks in advance
Model:
'Elemet' '=' (Object += Element_1)+
'Result' '=' Elements = [Element] // ***
'finisch'
Element_1:
name= ID
Element:
name = [Element_1] '['Categories = Category ']'
Category:
name= ID
[Updated on: Fri, 29 April 2016 11:43]
Report message to a moderator
Re: Problem by reference in Xtext [message #1730856 is a reply to message #1730853] Fri, 29 April 2016 10:28 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi i dont get your question. you reference an Element that you never declare.
maybe you mean
Model:
'Result' '=' Elements = [Element_1] // ***
+ a scoping rule that restricts the visible element_1 to the ones defined in the models "object" list.
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: Problem by reference in Xtext [message #1730863 is a reply to message #1730856] Fri, 29 April 2016 11:43 Go to previous messageGo to next message
Member
with 'element' I wanted receive a list from the objects
under 'member' has it possible name to enter but but all names are not categorized
and with Result with result I wanted the following receive : Object Name and the appropriate category
Editor exemple:
Element: Table, Door, Blackboard, Spoon, Cap
result: Spoon household article , Table school.// error by table and Spoon
finisch
[Updated on: Fri, 29 April 2016 11:44]
Re: Problem by reference in Xtext [message #1730868 is a reply to message #1730863] Fri, 29 April 2016 12:14 Go to previous messageGo to next message
'Result' '=' Elements +=Element (","Elements +=Element)*
Re: Problem by reference in Xtext [message #1730873 is a reply to message #1730868] Fri, 29 April 2016 12:29 Go to previous messageGo to next message
Member
thank you, it works
but i have another Problem
I want this time with 'Finish' only either Spoon or table to select ie: choose only the element that are used in 'Result'
Model:
'finisch' '=' finsch = [Element]
Element_1:
name= ID
Element:
Category:
name= ID
Editor exemple:
finisch Spoon //error
[Updated on: Fri, 29 April 2016 12:41]
Re: Problem by reference in Xtext [message #1730875 is a reply to message #1730873] Fri, 29 April 2016 12:32 Go to previous messageGo to next message
hi i dont get this question. you grammar and model dont match.
is this about parsing or about validation/restricting scope
Re: Problem by reference in Xtext [message #1730883 is a reply to message #1730875] Fri, 29 April 2016 13:52 Go to previous messageGo to next message
Member
Grammar:
Model:
'Element' '=' (objects += Element_1)+
'Result' '=' elements +=Element (","elements +=Element)*
'finish' '=' finsh = [Element]
Element_1:
name= ID
Element:
name = [Element_1] '['category = Category ']'
Category:
name= ID
Example:
Element = Table Door Blackboard Spoon Cap
Result = Spoon [household_article], Table [school]
finish = Spoon // Here occurs an error "Couldn't resolve reference to Element 'Spoon'."
For "Finish" i want to be able to specify elements which are used in"Result" but not in "Element". So in this example it should be possible to specify only "Spoon" and "Table" in the "Finish" part.
Thank you for your help Smile
Re: Problem by reference in Xtext [message #1730886 is a reply to message #1730883] Fri, 29 April 2016 14:02 Go to previous message
crosss refs as name do not work out of the box =>
class MyDslRuntimeModule extends AbstractMyDslRuntimeModule {
	override bindIQualifiedNameProvider() {
		MyDslNameProvider
		MyDslNameProvider
Previous Topic:Xtext DSL to Binary conversion
Next Topic:Accessing Class annotation values from JvmDeclaredType?
Current Time: Wed Nov 13 08:03:01 GMT 2019
Powered by FUDForum. Page generated in 0.02254 seconds
