Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Developing new Function Blocks
Developing new Function Blocks [message #1725670] Sun, 06 March 2016 12:36 Go to next message
Long Tran Phu is currently offline Long Tran PhuFriend
I am following the instruction of creating FB - the FlipFlop as BFB instructions.
I got 2 problems:
1. The Null State (Inital state) cannot add the action
2. I change the algorithm to as similar as BOOL2BOOL function block. However when I test by FBTester, it doesn't work (So nothing in the output). The BOOL2BOOL work quite well.
Could you please tell me the correct way to make a FB ?.
Thank you so much,
Re: Developing new Function Blocks [message #1725682 is a reply to message #1725670] Sun, 06 March 2016 19:47 Go to previous message
Alois Zoitl is currently offline Alois ZoitlFriend
ad 1) according to IEC 61499-1 the initial state of an ECC must not have actions.
ad 2) did you export your new FB and recompiled FORTE as described in the tutorial? Are you starting your selfcompiled FORTE?
Previous Topic:Homepage general
Next Topic:Raspberry Pi platform support
Current Time: Tue Aug 14 21:23:43 GMT 2018
Powered by FUDForum. Page generated in 0.01541 seconds
