Just a starting point [message #1717040] |
Wed, 09 December 2015 12:31  |
I am wanting to investigate an application that was written with Eclipse and SWT many years ago. The program is called AppleCommander and the source is available here.
sourceforge.net/projects/applecommander/files/
I'm not going to lie; I am not a Java programmer and have never touched Eclipse. (I have programmed in a couple of other languages.) However, this application has lain dormant for many years and I'm highly motivated to get it working in a more modern iteration of Java.
(To be clear, the command-line tools work fine. It's the GUI part that doesn't work unless the user installs Java 6 in order to be able to run the 32-bit SWT.)
At the moment, I just want to figure out how to load the source into Eclipse to the point where I can attempt a build and see what breaks.
I'd like to know where I should begin. Should I start at the Eclipse documentation? Suggestions, please.
m
FUDForum. Page generated in 0.09001 seconds
