Home » Newcomers » Newcomers » Does Eclipse create a new Jre for JDT ?(What happens when we have a new Installed Jre)
Does Eclipse create a new Jre for JDT ? [message #1716326] Wed, 02 December 2015 22:49 Go to next message
So Eclipse starts on the jre specified in eclipse.ini ( -vm )
1. When does it switch to the 'Installed JRE" if a different one is specified ?
( During JDT start ? Or only during java compile ? )
2. is the Installed Jre run as a new process ? ( Or is it somehow run as a new thread ? )
( It has to be a new process as you can give different memory limits to the Installed Jre )
3. I know eclipse can be directly started using java/javaw . I was thinking that the initial native code will launch java/javaw after showing the splash screen. But when I looked at the processes in windows task manager, I only saw eclipse.exe
Re: Does Eclipse create a new Jre for JDT ? [message #1716388 is a reply to message #1716326] Thu, 03 December 2015 07:40 Go to previous message
The preferences under Java > Installed JREs are not used for running eclipse, but as the runtime for programs developed with JDT. As such you can configure your Java project to find the runtime libraries (rt.jar etc) in any of the installed JREs and when running / debugging your application you can choose between any of the installed JREs.
I don't think there is any use case for switching Eclipse itself from one JRE to another, i.e., specifying -vm in eclipse.ini once and for all should be sufficient.
HTH,
Stephan
Previous Topic:Eclipse and Portlets
Next Topic:How to show Functions of a Python-File in the Package Explorer/Navigator on the left side?
Current Time: Wed Apr 30 02:44:57 EDT 2025
Powered by FUDForum. Page generated in 0.08179 seconds
