Parsing Errors in Eclipse DS-5 with Parasoft Plugin [message #1715984] |
Mon, 30 November 2015 02:16  |
Hi Everyone,
Currently I am using C++ application which is developed under the platform Eclipse based DS-5. In that my application consists of some of build errors which can be gets parsed using armcc with predefined parser settings on Eclispe.
After selection of Error parsers in C++ build->Settings->Error parsers tab my application had build successfully and .axf, .bin file have been generated.
And the problem that I am facing is, while after integrating the Parasoft C++ test plugin into Eclipse, the plugin and configurations related to Parasoft have been included into my ARM DS-5. And if i try to perform a static test using Parasoft plugin in DS the parse errors which already gets skipped during general build in DS is not getting parsed/skipped in same IDE using Parasoft plugin.
Because of that the test had been exited with reporting the same parse errors. Is there any specific Error parser settings for Parasoft plugin access in ARM DS-5? Can anybody suggest me some solutions to resolve this?
Thanks in advance.
FUDForum. Page generated in 0.07922 seconds
