Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFStore] LoginService
[EMFStore] LoginService [message #1713888] Sat, 07 November 2015 14:33 Go to next message
Scott Dybiec is currently offline Scott DybiecFriend
I'm integrating some code with the EMFStore Server --- code that will
run inside the same JVM along with the server. I would like to be able
to integrate with the LoginService ---- more specifically to be able to
verify user credentials without creating a session.
Would it be possible to add a method similar to this to EMFStore's
org.eclipse.emf.emfstore.internal.server.accesscontrol.LoginService?
public boolean verifyUser(String username, String password,
ESClientVersionInfo clientVersionInfo) {
boolean isVerified;
try {
getUserVerifierService().verifyUser(
username,
password,
clientVersionInfo);
isVerified = true;
} catch (AccessControlException ex) {
isVerified = false;
return isVerified;
or
public ESAuthenticationInformation verifyUser(String username, String
password,
ESClientVersionInfo clientVersionInfo) throws AccessControlException {
return getUserVerifierService().verifyUser(
username,
password,
clientVersionInfo);
Or to provide some other mechanism for providing the ability to verify a
user's credentials w/o creating a session.
As an alternative I could call LoginService.logIn() followed by
LoginService.logOut(), but it seems wasteful to create and destroy a
session just to verify credentials.
$cott
Re: [EMFStore] LoginService [message #1714060 is a reply to message #1713888] Mon, 09 November 2015 16:19 Go to previous messageGo to next message
Edgar Mueller is currently offline Edgar MuellerFriend
Member
Hi Scott,
I can't say for sure that such a method would be placed in the
LoginService, but we should be able to come up with a more sophisticated
solution to check for the validity of a single user without the need of
creating a session first.
Please open a feature request via Bugzilla.
Edgar
Edgar Mueller
Get Professional Eclipse Support:
http://eclipsesource.com/en/services/developer-support/
Re: [EMFStore] LoginService [message #1714474 is a reply to message #1714060] Thu, 12 November 2015 22:02 Go to previous message
Done.
On 11/9/2015 11:19 AM, Edgar Mueller wrote:
> Hi Scott,
> Edgar
Previous Topic:how to edit a emf.ecore in xtext
Next Topic:[Edapt] BackwardConverter causes NP upon feature removal
Current Time: Thu Dec 03 23:54:55 GMT 2020
Powered by FUDForum. Page generated in 0.02690 seconds
