Home » Newcomers » Newcomers » "install modeling components" menu item not available
"install modeling components" menu item not available [message #1710453] Tue, 06 October 2015 15:47 Go to next message
I just installed the 64-bit version of Eclipse Mars on Windows 7. I want to install Papyrus, but the menu item "install modeling components" doesn't appear in the Help menu or anywhere else.
Anyone know what might be going on?
Lily
Re: "install modeling components" menu item not available [message #1710466 is a reply to message #1710453] Tue, 06 October 2015 21:01 Go to previous messageGo to next message
What makes you think it should appear there?
Re: "install modeling components" menu item not available [message #1710541 is a reply to message #1710466] Wed, 07 October 2015 08:40 Go to previous messageGo to next message
"What makes you think it should appear there? "
Hi Nitin,
I've also installed Eclipse Mars on my MacBook (running Yosemite) and it appears on that install. More importantly, I need that to install Papyrus - which I've done on the MacBook install.
Lily
Re: "install modeling components" menu item not available [message #1710547 is a reply to message #1710541] Wed, 07 October 2015 08:54 Go to previous messageGo to next message
Lily,
In the worst case, you can use the Install New Software to install it.
> Hi Nitin,
> Lily
Re: "install modeling components" menu item not available [message #1710550 is a reply to message #1710547] Wed, 07 October 2015 09:15 Go to previous messageGo to next message
Which Eclipse package did you download? Sounds like you got a different one on the Mac than you did for Windows.
Re: "install modeling components" menu item not available [message #1710611 is a reply to message #1710550] Wed, 07 October 2015 17:37 Go to previous messageGo to next message
Hi Eric,
You're right - I have 4.5.0 on the MacBook, and 4.5.1 on the PC. But I didn't see anything in the 4.5.1 "issues" list about not being able to install modeling components.
Would anyone know if that feature has been removed (and why) on the 4.5.1 version?
Lily
Re: "install modeling components" menu item not available [message #1710619 is a reply to message #1710611] Wed, 07 October 2015 21:02 Go to previous messageGo to next message
Not the version, I'm asking about which package. Eclipse is distributed in packages, each a collection of features/plugins that are commonly used together. They are what you see on the main Downloads page, such as Eclipse IDE for Java EE Developers, Eclipse Modeling Tools, etc.* My guess is that you selected different packages for the two machines. One of them includes the feature you're talking about, the other does not.
* If you used the (new) Eclipse Installer, you also have the opportunity to select a package to install.
[Updated on: Wed, 07 October 2015 21:05] by Moderator
Re: "install modeling components" menu item not available [message #1711271 is a reply to message #1710619] Wed, 14 October 2015 09:34 Go to previous message
Hello Eric,
Thanks for the pointer. You were right about the different packages. What happened is that, using the new Eclipse Installer, I somehow ended up with two different version of Eclipse - one with the modeling tools, the other without. Anyhow, I compared the "installation details" of the Mac and the (right) PC versions and made them the same.
Thank you!
Lily
Previous Topic:Shell in eclipse to run manually methods of created objects
Next Topic:need to create override-web.xml but can't modify war-file
Current Time: Thu Apr 17 20:46:09 EDT 2025
Powered by FUDForum. Page generated in 0.09195 seconds
