Home » Eclipse Projects » Eclipse Platform » DetailsPart and registered pages
DetailsPart and registered pages [message #327329] Tue, 15 April 2008 11:41 Go to next message
I have a master/details page. I have objects in the master page. Some of
the items in the master like are like staff, manager, president... that all
extend Person. I want the selection to bring up the same page for all of
these selections.
detailsPart.registerPage(Person.class, new PersonDetailsPage());
but this doesn't work. I need to implement this for each class. Is that
correct?
Re: DetailsPart and registered pages [message #327340 is a reply to message #327329] Tue, 15 April 2008 15:56 Go to previous messageGo to next message
> these selections.
> correct?
To use registered pages the answer is yes. It is also possible to use a
DetailsPageProvider and build pages that depend on the input class
without registering the pages ahead of time.
Re: DetailsPart and registered pages [message #327341 is a reply to message #327340] Tue, 15 April 2008 16:24 Go to previous messageGo to next message
Is this a bug or the way its supposed to work by design? Is there a way to
have all the children use the same page without listing all the classes? We
would like to be able to extend this to unknown classes.
"Steve Blass" <sblass@acm.org> wrote in message
news:fu31ar$i75$1@build.eclipse.org...
>> of the items in the master like are like staff, manager, president...
>> that all extend Person. I want the selection to bring up the same page
>> for all of these selections.
>> correct?
> DetailsPageProvider and build pages that depend on the input class without
Re: DetailsPart and registered pages [message #327369 is a reply to message #327341] Wed, 16 April 2008 12:38 Go to previous message
To use the same page for all the children regardless of type and with
unknown classes the DetailsPageProvider approach is your friend.
in the MasterDetailsBlock declare something like
private IDetailsPageProvider myDetailsPageProvider;
then create the DetailsPageProvider in the M/D block constructor
myDetailsPageProvider=new DetailsPageProvider(...);
so that your registerPages method can say something like
void registerPages(DetailsPart detailsPart) {
detailsPart.setPageProvider(myDetailsPageProvider);
Now, DetailsPageProvider looks something like
public class DetailsPageProvider
implements IDetailsPageProvider {
public DetailsPageProvider(...) {
// TODO Auto-generated constructor stub
/* (non-Javadoc)
* @see
org.eclipse.ui.forms.IDetailsPageProvider#getPageKey(java.la ng.Object)
public Object getPageKey(Object object) {
return object;
/* (non-Javadoc)
* @see org.eclipse.ui.forms.IDetailsPageProvider#getPage(java.lang. Object)
public IDetailsPage getPage(Object key) {
return new ObjectDetailsPage(key);
And from there it is all about whatever you want ObjectDetailsPage to
put on the form -
public class ObjectDetailsPage
implements IDetailsPage {
public ObjectDetailsPage(Object key) {
/* (non-Javadoc)
* IDetailsPage#createContents(org.eclipse.swt.widgets.Composit e)
public void createContents(Composite parent) {
// here you get to create whatever form you
// want for the input object
// or you can use the same page for every object
HTH,
Steve
>>> correct?
Previous Topic:Compiling Eclipse Code
Next Topic:silly issue when using ITreeContentProvider
Current Time: Sat Mar 22 12:56:23 EDT 2025
Powered by FUDForum. Page generated in 0.03123 seconds
