Home » Newcomers » Newcomers » Mars CSS Unknown Property(How To FIX)
Mars CSS Unknown Property [message #1707528] Mon, 07 September 2015 01:41
Dwight Norris is currently offline Dwight NorrisFriend
Ok something went wrong with my Eclipse Luna install after the frustration of trying to create a EXE file YES i have used Luna for more than a year any way I installed the All in ONE Eclipse Mars now I have this WARNING with my CSS application file
The real frustration is no one on StackOverflow or here has addressed this issue
So what i am asking is how to FIX the issue
thank you in advance
I have tried this but do not know how to write a RULE
from SO
1. Right-click on your project and select Properties
2. Under Validation, check the Enable project specific settings box.
3. Scroll down and select Web Resources Validator.
4. If there is an Include Group and it contains File extension: css, try removing it an then re-validating your project. If the rule is not there, then Add Rule into the existing Include Group, or make a new Include Group.
Maybe you've already tried something like this.
Previous Topic:Identifying AptanaStudio3 editors in Eclipse's "Open with ..." dialog, & setting them
Next Topic:[TYCHO] "eclipse-plugin" no longer supported when running "mvn eclipse:eclipse"
Current Time: Mon Oct 26 16:53:43 GMT 2020
Powered by FUDForum. Page generated in 0.02910 seconds
