Home » Newcomers » Newcomers » Sonar-Plugin / Error: Could not find or load main class MAVEN_OPTS
Sonar-Plugin / Error: Could not find or load main class MAVEN_OPTS [message #1705005] Tue, 11 August 2015 07:41 Go to next message
I use following versions:
Tomcat 8.0.24
Hudson 3.3.0
Sonar-Plugin 2.0.1
Maven 3.0.5 / 3.2.5
JDK 1.7.0_45
MAVEN_HOME is set, JAVA_HOME is set.
When I set the MAVEN_OPTS:
-Xmx2048m -XX:MaxPermSize=512m
or other values for the sonar-plugin I get the error:
With MAVEN_OPTS in the maven-build there are no problems.
What could be wrong? What is to do?
Thranks and greetings
Elko
Re: Sonar-Plugin / Error: Could not find or load main class MAVEN_OPTS [message #1714032 is a reply to message #1705005] Mon, 09 November 2015 08:47 Go to previous messageGo to next message
Hey
do you have any news
I am facing the same problem
Francois
Re: Sonar-Plugin / Error: Could not find or load main class MAVEN_OPTS [message #1714034 is a reply to message #1714032] Mon, 09 November 2015 08:51 Go to previous message
SonarQube is a third-party product, so you should seek help in whatever support channel they provide.
Previous Topic:eGit question. One project showing as seperate folder in eclipse...
Next Topic:Using standard libraries while offline
Current Time: Sat Apr 19 15:14:07 EDT 2025
Powered by FUDForum. Page generated in 0.09161 seconds
