Customize edge style [message #1694595] |
Wed, 06 May 2015 14:11  |
Julien Siega Messages: 8 Registered: September 2014 |
Junior Member |
Hi everyone,
I want to change the default style of edge to "avoid obstruction", there is any existing extension point to do this ? or i need to do it with a listener on Edge ?
I see that there is a preference page for the rooting style, maybe it would be interesting to have the same things for the "closest distance" and "avoid obstruction" in the preference or the odesign. I don't know if there is any easier way to do this and if someone already ask for something like that. But if we do something maybe the community will be interested by our works.
Julien
[Updated on: Wed, 06 May 2015 15:30] Report message to a moderator
Re: Customize edge style from preferences [message #1694987 is a reply to message #1694595] |
Mon, 11 May 2015 08:48  |
Le 06/05/2015 16:11, Julien Siega a écrit :
> Hi everyone,
> listener on Edge ?
There is not extension point to do this.
> I see that there is a preference page for the rooting style,maybe it
The preference page for routing style override a style property
available in the VSM (odesign file). So it is not really the same for
"closest distance", "avoid obstruction" and "jump links" properties (not
currently exposed in VSM).
> I don't know
Indeed, we can imagine to complete the connections preference page for
default values for all these properties.
You can create a bugzilla for this feature. This looks like an
interesting area to explore. Make sure you state your intent to explore
it on the sirius-dev mailling list.
Technical information for implementation: The above properties can be
set here in Sirius:
org.eclipse.sirius.diagram.ui.internal.view.factories.DEdgeViewFactory.decorateView(View,
View, IAdaptable, String, int, boolean):
org.eclipse.gmf.runtime.notation.RoutingStyle.setAvoidObstructions(boolean)
* org.eclipse.gmf.runtime.notation.RoutingStyle.setClosestDistance(boolean)
* org.eclipse.gmf.runtime.notation.RoutingStyle.set...
> Thanks
> Julien
Laurent
Laurent Redor - Obeo
Need professional services for Sirius?
FUDForum. Page generated in 0.01923 seconds
