Home » Eclipse Projects » Eclipse Platform » Error retrieving "feature.xml" [error opening zip file]
Error retrieving "feature.xml" [error opening zip file] [message #322724] Tue, 27 November 2007 00:55 Go to next message
Bucky Pope is currently offline Bucky PopeFriend
I get this error trying to do Software Updates: Find and Install. I get
the error twice, but I can't tell which feature is causing the problem.
How can I find and fix this problem. It seems to be preventing me from
installing new features.
Re: Error retrieving "feature.xml" [error opening zip file] [message #322779 is a reply to message #322724] Wed, 28 November 2007 17:36 Go to previous message
Prince Singh is currently offline Prince SinghFriend
Could be an unpacked feature installed in your eclipse/features directory.
Check if eclispe/features directory contains any feature in a
non-directory format (i.e. jar, zip, etc.)
Check if the workspace error log helps. You can find it under
/path/to/workspace/.metadata/.log
Prince Singh
Drishti-Soft Solutions Pvt. Ltd.
Previous Topic:Added dependency + not added to Plugin dependency library
Next Topic:saving/restoring resource properties in a project
Current Time: Mon Oct 22 09:27:54 GMT 2018
Powered by FUDForum. Page generated in 0.01890 seconds
