Home » Archived » Visual Editor (VE) » performance of Eclipse java Editor
performance of Eclipse java Editor [message #32204] Thu, 22 April 2004 19:57 Go to next message
Hi folks,
this problem might not be specific to VE. I built a GUI using VE and the
source code is about 2600 lines long. When I try to manually type in the
java Editor, it becomes incredible slow. I went to
Window->preferences->Java->Editor and unchecked everything under appearance
tab and code assist tab. It helped somewhat, but still the delay is
unbearable. What's the reason behind this? How do I turn off the feature
that's causing this?
thanks!!
-jonathan
Re: performance of Eclipse java Editor [message #32450 is a reply to message #32204] Fri, 23 April 2004 06:48 Go to previous messageGo to next message
Hi Jonathan,
Can you try closing the project and re-opening it ?
For a clean start of Eclipse can you edit the file in the Java Editor,
then open the VE and close it, and then edit the file in the Java
Editor. The thing I'm keen to find out is whether somehow closing the
Visual Editor didn't clean up in which case it is still somehow
listening to the Java document and doing things. Look at the task
manager and the number of javaw programs (one is started for each
editor) and see whether this goes up by 1 when the VE is opened and down
again when it is closed.
Joe
Re: performance of Eclipse java Editor [message #32485 is a reply to message #32450] Fri, 23 April 2004 10:44 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Also try editing it with the java editor and not the ve editor. 2600
lines is pretty long. I have one like that and it too is slow in the
java editor. That would eliminate whether it is the java or the ve
editor that is problem.
Thanks, Rich Kulp
Re: performance of Eclipse java Editor [message #88316 is a reply to message #32485] Sat, 23 April 2005 15:56 Go to previous messageGo to next message
Originally posted by: twilliamsark.yahoo.com
I'm running into a similiar performance problem in VE. I heard that
there is a setting that is supposed to turn off synchronization
between the code and the graphical representation but can't find it.
Any heard of this?
On Fri, 23 Apr 2004 10:44:17 -0400, Rich Kulp
Re: performance of Eclipse java Editor [message #88481 is a reply to message #88316] Mon, 25 April 2005 09:58 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
There is but when you turn it back on again it will have to a reload to
handle all of the changes made.
It is the "pause" button the toolbar. It looks like the pause on tape
recorder, two vertical yellow bars.
Rich Kulp
Re: performance of Eclipse java Editor [message #586970 is a reply to message #32204] Fri, 23 April 2004 06:48 Go to previous message
Hi Jonathan,
Joe
Re: performance of Eclipse java Editor [message #586984 is a reply to message #32450] Fri, 23 April 2004 10:44 Go to previous message
Thanks, Rich Kulp
Re: performance of Eclipse java Editor [message #607224 is a reply to message #32485] Sat, 23 April 2005 15:56 Go to previous message
Any heard of this?
Re: performance of Eclipse java Editor [message #607235 is a reply to message #88316] Mon, 25 April 2005 09:58 Go to previous message
Rich Kulp
Previous Topic:Instantiating derrived component
Next Topic:newbie following tutorial, immediate exception
Current Time: Sat Jun 21 04:59:10 EDT 2025
Powered by FUDForum. Page generated in 0.07723 seconds
