Re: Wait for a job to finish before proceeding [message #1632496 is a reply to message #1630566] |
Tue, 24 February 2015 10:00 |
Test execution can't be longer than global timeout. Of course, you can increase timeout but we don't recommend it, because it can just hide a possible problem.
It seems your test fails to execute properly because context fail to restore a part of state required for a test to proceed and test hangs forever in a cycle. This is indicated by the test dependency on test suite.
Could you please attach Execution details for a test hangup diagnostic?
Yours sincerely,
Olga.
Re: Wait for a job to finish before proceeding [message #1638827 is a reply to message #1632496] |
Fri, 27 February 2015 10:08 |
Chris Champion Messages: 49 Registered: February 2014 |
Member |
Hi Olga,
Is there then no way to request the status of a job, e.g. "Running", "Waiting", etc.?
Execution details just says:
Report:
Test case *01 Create new Database - Create a new database* time: 15 m 50 s
Result: CANCEL, message: Execution is canceled by timeout: 300000
--------------Logs BEGIN-------------------
--------------Logs END-------------------
Thank you,
Chris
[Updated on: Fri, 27 February 2015 14:05] Report message to a moderator
Re: Wait for a job to finish before proceeding [message #1681953 is a reply to message #1665371] |
Tue, 17 March 2015 14:31 |
Member |
Hi Olga,
I was able to test with the latest NB 1.5.5.201503042108 and am still getting the error when I run on default settings:
Execution timed out after 300 seconds
I tried adding--set-q7-option -key jobDebugjobTimeout -value 12000000--to the beginning of the test case because I don't want to change the global settings to run these handful of test cases.
Test case script:
get-view "AdminView" | get-tree | select ... | get-menu "Delete Database and Datafiles" | click
get-window "Confirm Database Deletion" | get-button OK | click
loop {
if [windowExists "Deleting Database ..." | eq true] {
wait 1000
recur
get-view Progress | get-button "Remove All Finished Operations" | click
get-view "AdminView" | get-tree | select ... | get-menu "Create Database" | click
with [get-window -class WizardDialog] {
get-group "Installation Options" | get-button "Create a new database" | click
get-group "Database Configuration" | get-editbox
-after [get-label "Required memory (% of total memory)"] | set-text 10
get-button Finish | click
loop {
if [windowExists "Creating Database ..." | eq true] {
wait 1000
recur
get-window "Admintool" | get-object | save-screenshot "C:/Users/.../RCPTT/Screenshots/AdminTool_Testplan/Admin_01-InstallNewDB.png"
Attaching report and execution details.
Thank you,
Chris
[Updated on: Tue, 17 March 2015 14:33] Report message to a moderator
Re: Wait for a job to finish before proceeding [message #1682022 is a reply to message #1681953] |
Tue, 17 March 2015 15:09 |
Member |
I've tried all of the "set-q7-options" ECL commands but the only way I'm able to run these tests successfully is with loops waiting for a window to close
loop {
if [windowExists "Creating Database" | eq true] {
wait 1000
recur
and extending the Launch timeout (sec) in Preferences.
Is it possible to change the launch timeout only for specific test cases, or for a specific AUT instead of globally?
Thank you,
Chris
[Updated on: Tue, 17 March 2015 15:11] Report message to a moderator
Re: Wait for a job to finish before proceeding [message #1689286 is a reply to message #1687135] |
Mon, 23 March 2015 08:04 |
There is no setting to change execution timeout only for one test case.
If you raise timeout up to 10 minutes it doesn't affect time of execution.
If you have several test cases which are failing with timeout, you can just skip them until you fixed the root cause of timeout.
I may suggest just run this test separately from other test cases in IDE or with runner and different values of testExecTimeout in testOptions
Yours sincerely,
Olga.
FUDForum. Page generated in 0.02979 seconds
