IBM contribution - plugs don't show in Eclipse [message #30802] |
Sat, 24 July 2004 13:40  |
Originally posted by: mike.home.net
Having installed everything as per the "Getting Started" guide, Eclipse
doesn't pick up on the presence of the newly installed plugins. E.g. Under
Window->Show view->Other there is no entry for "Data".
Any ideas what I may be doing wrong?
M
Re: IBM contribution - plugs don't show in Eclipse [message #31399 is a reply to message #31183] |
Sun, 25 July 2004 23:41   |
Originally posted by: engebret.mchsi.com
I had the same problem initially too. What I ended up doing was just
downloading a fresh install of
eclipse and then installing the ibm.zip files and the other required
eclipse libraries (GEF, VE, etc). After
that I was able to use the new ibm options. My current theory is that I
had other plugins in my old
eclipse install that might have conflicted, not sure if that is possible
but you never know :0)
Mike wrote:
> That doesn't seem to help - I already had VE installed anyway, as it's in
> the list on the "Getting Started" page.
> Mike
> "Rui Figueira" <rui.figueira@vilt.com.pt> wrote in message
> news:ce008v$frh$1@eclipse.org...
> > Hi,
> > I had the same problem. Then I installed VE and now everything seems to
> > work fine.
> > Mike wrote:
> > > Hi,
> Under
> > > Thanks,
> > > M
FUDForum. Page generated in 0.27940 seconds
