  Mobile Application support
Discussions on the approach to Mobile Applications
By: Nedelcho Delchev on Sat, 07 November 2015
4 2017 Mon, 23 April 2018 20:40
By: Jupp Schmitz
  Kafka as a Messaging Hub
By: Nedelcho Delchev on Sat, 06 May 2017
1 32162 Thu, 14 September 2017 09:20
By: johny kopparapu
  Node.js vs J2V8
Node.js vs J2V8 Discussion
3 37797 Sat, 27 May 2017 09:08
  Plan Version 3
Major changes in version 3.x
28 11154 Wed, 17 May 2017 14:41
  Vert.x for reactive apps
Reactive Apps
By: Nedelcho Delchev on Wed, 17 May 2017
0 13726 Wed, 17 May 2017 14:40
  New Repository Structure
Restructuring current Repository hierarchy
By: Yordan Pavlov on Fri, 12 May 2017
4 3151 Mon, 15 May 2017 11:10
  Remove Semantic Folders
Remove First Level Semantic Folders
1 23720 Fri, 12 May 2017 17:15
  Support for CommonJS
By: Georgi Pavlov on Tue, 09 May 2017
1 27089 Thu, 11 May 2017 07:45
  Integrated Client-side JS testing
0 32874 Tue, 09 May 2017 13:58
By: Georgi Pavlov
  Release service
0 32869 Tue, 09 May 2017 13:54
By: Georgi Pavlov
  Improved support for BDD and TDD for JS scripting services
0 32900 Tue, 09 May 2017 13:43
By: Georgi Pavlov
  Cache and global context
0 33273 Tue, 09 May 2017 13:34
By: Georgi Pavlov
  Support for the "realtime" usecases
0 33337 Tue, 09 May 2017 13:25
By: Georgi Pavlov
  Adoption of NodeJS applications
0 33403 Tue, 09 May 2017 13:07
By: Georgi Pavlov
  ES6 Runtime for Scripting Services
0 33392 Tue, 09 May 2017 12:53
By: Georgi Pavlov
  Ops cockpit
Support for the operator
0 33376 Tue, 09 May 2017 12:47
By: Georgi Pavlov
  Support for more types of protection mechanisms per app
multi factor authentications, certifactes, etc configurable per-app
0 33380 Tue, 09 May 2017 12:36
By: Georgi Pavlov
  Supportability: Improved debugging of Scripting Services
0 33423 Tue, 09 May 2017 12:25
By: Georgi Pavlov
  Improved Git support
0 33547 Tue, 09 May 2017 12:07
By: Georgi Pavlov
  Improved extensions management
0 33545 Tue, 09 May 2017 11:59
By: Georgi Pavlov
  Design time control of published runtime artifacts
0 33561 Tue, 09 May 2017 11:09
By: Georgi Pavlov
  Production readiness
Discussion for the required tools and processes that would nativly support production-ready releases in Dirigible
0 34081 Tue, 09 May 2017 10:57
By: Georgi Pavlov
  More fresh, desktop-grade design-env UX
0 34332 Tue, 09 May 2017 09:23
By: Georgi Pavlov
  PostgreSQL as a Default Database
0 29258 Sat, 06 May 2017 15:11
  Cassandra as a Repository Implementation
0 29253 Sat, 06 May 2017 15:02
  Activiti as a Process Engine
Include Activiti as a built-in process engine
0 29493 Sat, 06 May 2017 13:55
icon3.gif Dirigible Cloud Management
Discussion about Dirigible Cloud Management user experience
By: Nedelcho Delchev on Mon, 14 March 2016
9 7641 Sat, 06 May 2017 13:38
  AppServer as non-OSGi
Application Server Component to be based on non-OSGi framework
0 29536 Sat, 06 May 2017 13:32
  Secured/Unsecured URLs Discussion
Discussion about path changes after securing a url
By: Viktor Marinov on Mon, 14 November 2016
1 65850 Sat, 06 May 2017 13:17
  Injected API Requests
Requests for new Injected APIs
By: Nedelcho Delchev on Tue, 25 August 2015
4 4600 Mon, 01 August 2016 12:44
  JavaScript Engine Types Determination
Discussion about JavaScript engine types and their support
By: Nedelcho Delchev on Tue, 28 June 2016
1 1179 Tue, 28 June 2016 12:28
By: Yordan Pavlov
  Dirigible Testing Lab
By: Ekaterina Mitova on Mon, 25 April 2016
25 7009 Wed, 27 April 2016 06:43
icon5.gif Messaging Service API discussion
Discussion about Messaging Service API
By: Nedelcho Delchev on Fri, 21 August 2015
1 8707 Mon, 14 March 2016 07:49
  Supportability: Remote debugging dirigible code
By: Georgi Pavlov on Thu, 10 December 2015
2 2200 Mon, 14 December 2015 15:32
By: Georgi Pavlov
  Integration of 3d party libraries
Possible options and use cases
By: Georgi Pavlov on Wed, 09 December 2015
1 1811 Sat, 12 December 2015 11:12
  NoSQL support with TinkerPop
By: Georgi Pavlov on Mon, 30 November 2015
2 1520 Tue, 01 December 2015 10:26
By: Georgi Pavlov
  High-performance & scalable Runtime
What would be the target architecture and components for a high-performance & scalable Runtime
1 3991 Fri, 13 November 2015 08:22
  A/B Testing
Discussion about A/B Testing requirements from application developers
By: Nedelcho Delchev on Mon, 19 October 2015
1 4939 Fri, 23 October 2015 11:49
By: Pavel Genevski
  Dirigible CodeWeek Workshop - Feedback
Dedicated topic for gathering feedback from participants of Dirigible CodeWeek Workshop (2015-10-17)
4 1225 Tue, 20 October 2015 12:10
By: Yordan Pavlov
  Performance issue with spring/eclipse classloader
classes loaded by spring (java reflection) are not cached
By: Marouen Allala on Fri, 16 October 2015
2 1246 Mon, 19 October 2015 07:22
By: Marouen Allala
  Dependency injection for Java scripting services
By: Pavel Genevski on Fri, 18 September 2015
0 3364 Fri, 18 September 2015 08:48
By: Pavel Genevski
  IoT Scenario
Possible use cases and development scenarios for IoT projects with Dirigible
By: Yordan Pavlov on Sat, 12 September 2015
0 2430 Sat, 12 September 2015 10:58
By: Yordan Pavlov
  Server vs. Server-less in RCP mode
Pros and Cons about running a built-in server in RCP mode
By: Nedelcho Delchev on Fri, 11 September 2015
0 4779 Fri, 11 September 2015 13:15
  Welcome to eclipse.dirigible
By: Eclipse Webmaster on Thu, 19 March 2015
0 1818 Thu, 19 March 2015 14:55
Current Time: Wed Jul 18 16:41:48 GMT 2018
Powered by FUDForum. Page generated in 0.01892 seconds
