M2M for M2T instead of Acceleo? |
2989 |
Thu, 06 January 2022 05:55 By: Ed Willink |
Henshin pattern matching for units Henshin Transformations with automated pattern matching for units |
894 |
Tue, 28 December 2021 19:46 By: Ed Willink |
Help me Generate diagram code error: GMF |
865 |
Mon, 01 November 2021 19:11 By: Ed Willink |
UML - QVT Transformation problem |
870 |
Mon, 24 May 2021 13:05 By: Ed Willink |
[QVTo] BPMN2 Metamodel issues |
1410 |
Tue, 27 April 2021 08:26 By: Ed Willink |
[ATL] Transform only a part of the rules ? |
1700 |
Thu, 13 August 2020 07:03 By: Ed Willink |
Model-To-Model Sibling Child Problem |
5912 |
Fri, 30 August 2019 14:03 By: Burak Karaduman |
Own Model to XML Create and use model to parse text file and generate xml file |
1711 |
Mon, 19 August 2019 11:25 By: Ed Willink |
What Industry Wants from Academia in Software Modeling |
29273 |
Wed, 01 May 2019 13:53 By: mcse mcse |
MDA Automating Model transformation in Eclipse |
4221 |
Sat, 14 July 2018 11:40 By: Ed Willink |
ATL Transformations Zoo link not working |
3642 |
Fri, 01 June 2018 06:46 By: ashrafur rahman |
M2M from UML to REST |
2800 |
Mon, 23 April 2018 15:04 By: Ed Willink |
XTEND import function |
2288 |
Tue, 17 April 2018 15:37 By: Ed Willink |
[QVTo] Constructor calling constructor |
4125 |
Tue, 13 March 2018 15:48 By: Francesco Bedini |
[ATL] Ask for help problem rule atl beginnner level |
7660 |
Fri, 09 June 2017 10:30 By: saida Haidrar |
ATL : target model |
10697 |
Fri, 14 April 2017 21:54 By: im hello world |
widely used model transformation languages |
12284 |
Thu, 06 April 2017 10:32 By: Banafsheh Azizi |
XSLT vs ATL |
4435 |
Mon, 03 April 2017 14:59 By: Ed Willink |
error in if condition |
18796 |
Wed, 08 March 2017 11:02 By: Ed Willink |
refImmediateComposite() when two composits are available |
7031 |
Sun, 05 March 2017 20:39 By: Banafsheh Azizi |
"Binding" and "BindingStat" in ATL |
13725 |
Sun, 19 February 2017 11:32 By: Banafsheh Azizi |
"oclAsType" in ATL |
4117 |
Wed, 15 February 2017 17:44 By: Ed Willink |
Assignment statement in ATL helpers |
3171 |
Fri, 27 January 2017 02:18 By: Ruchika Kumar |
OCL metamodel constraint to ATL helper |
2991 |
Sat, 21 January 2017 17:04 By: Ed Willink |
[QVTo] how to use two target sources? By: Emre T on Mon, 27 May 2013 |
17421 |
Wed, 22 June 2016 09:01 By: Ed Willink |
Cross-referencing UML profiles in ATL Cross-referencing UML profiles from within Eclipse ATL |
4053 |
Sun, 27 March 2016 06:40 By: Ed Willink |
When is a transformation declarative or imperative? |
4001 |
Wed, 09 March 2016 16:18 By: Nicolas |
local variables: self=IN!<unnamed> By: Yi Zhu on Thu, 03 March 2016 |
3457 |
Fri, 04 March 2016 14:59 By: Yi Zhu |
[QVTo] Java program->Model->QVTo Transformation->Model->Java program Transform model created with MoDisco Discoverer |
3389 |
Tue, 15 December 2015 09:59 By: Denis Nikiforov |
[QVTo] Register blackbox and "Strings" units on a standalone application |
9803 |
Sat, 19 September 2015 02:00 By: Ulrich Lang |
[SOLVED] Generating random values |
3003 |
Thu, 21 May 2015 15:41 By: Peter Johnsen |
Transforming Ecore diagrams with mediniQVT Exception thrown at the transformation execution |
3272 |
Mon, 18 May 2015 12:42 By: Gonzalo Bressan Zuber |
QVTo constructor behavior when extending transformations |
3086 |
Mon, 23 March 2015 11:47 By: Teun van de Berg |
many to one mapping many to one mapping in ATL |
2332 |
Tue, 09 December 2014 17:19 By: Ed Willink |
Empty target model and the console showed no errors Empty target model and the console showed no errors |
4098 |
Tue, 02 December 2014 19:20 By: taghreed altamimi |
Empty target model got empty target model |
5160 |
Sun, 30 November 2014 20:02 By: taghreed altamimi |
[QVTo] how to query all objects from a referenced model ? |
3502 |
Fri, 31 October 2014 13:57 By: Julien Deantoni |
Choosing between ATL and QVT for model to model transformation |
3551 |
Thu, 05 June 2014 09:39 By: Nabil Benabdallah |
Create a C++ model from a Java 5 model |
4630 |
Thu, 24 April 2014 13:01 By: Sylvain EVEILLARD |
Data structures in QVTO |
4514 |
Tue, 18 February 2014 06:11 By: Ed Willink |
QVTO applyStereotype() issue ! is it a bug?!! applyStereotype() does not really apply stereotype to the output xmi file even getAppliedStereotypes() return correct result |
6909 |
Mon, 17 February 2014 01:09 By: Naif Mokhayesh |
XML to XMI transformation with mapping between Ecore and XSD |
24942 |
Fri, 14 February 2014 15:58 By: ModelGeek Mising name |
Multiple to One model Transformation In QVTO Transforming two model instances into a single model instance |
4570 |
Thu, 23 January 2014 12:27 By: Ed Willink |
Any API for implementing M2M transformation in Java? |
4502 |
Fri, 27 September 2013 23:10 By: Ed Willink |
[QVTo] Duplicated elements in target model |
3839 |
Thu, 01 August 2013 10:50 By: nicholas pacini |
Create UML Diagrams from other UML Diagrams |
3156 |
Fri, 05 July 2013 10:47 By: André Ribeiro |
Dependency transformation |
10159 |
Mon, 03 June 2013 09:55 By: Ed Willink |
qvto log() messages in java |
5812 |
Mon, 25 March 2013 14:44 By: Miriam Hundemer |
using blackbox in a qvt transformation called by java |
5384 |
Wed, 13 March 2013 19:00 By: Ed Willink |
[QVT] Calling QVT transformation from within java class |
13612 |
Sun, 10 March 2013 01:39 By: sohaib soso |
"Many-Model to Model" transformation with qvto? |
6932 |
Fri, 22 February 2013 16:17 By: Ed Willink |
Large Model, minor changes |
5869 |
Tue, 05 February 2013 20:56 By: Dennis Wagelaar |
org.eclipse.emf.mwe.utils.Reader is not working org.eclipse.emf.mwe.utils.Reader is not working |
6046 |
Mon, 04 February 2013 12:44 By: Ed Willink |
[ATL] M2M: a Set of target elements in the transformation |
3620 |
Mon, 14 January 2013 00:13 By: Jaroslav K. |
New QVT mailing lists |
5587 |
Wed, 19 December 2012 16:30 By: Ed Willink |
Ant ATL tasks command line execution |
4872 |
Wed, 05 December 2012 16:15 By: Dario Imparato |
[ATL]different transformed results between ATL configuration and Java programming transformation |
4917 |
Mon, 03 December 2012 13:04 By: Beatus Ding |
Behavioral features ( state machine) support import and preserve behavioral features of UML models |
10595 |
Fri, 23 November 2012 22:00 By: Ed Willink |
[ATL] XSD to ECORE ATL transformation |
4771 |
Fri, 16 November 2012 16:34 By: Mehdi Missing name |
creating psm |
3736 |
Fri, 09 November 2012 21:12 By: Ed Willink |
[ATL] Avoid duplicate entries in target model |
4900 |
Sat, 27 October 2012 05:53 By: Ed Willink |
ATL with Xtext Resource M2M Transformation of Xtext Resource |
7600 |
Sun, 21 October 2012 16:55 By: Artem G. |
[ATL] referencing to element created from a lazy rule By: Fy Za on Tue, 22 May 2012 |
5951 |
Tue, 21 August 2012 12:02 By: Gunnar Arndt |
Transform XML documents based on custom XSDs into UML model |
4470 |
Fri, 10 August 2012 18:58 By: Ed Willink |
[ATL][AML]Information on AML |
5315 |
Sat, 04 August 2012 19:56 By: Rachel sengineer |
[ATL] Unresolved cross-reference... Again |
7151 |
Mon, 16 July 2012 23:02 By: EtienneB Mising name |
M2M for genmodel |
5691 |
Mon, 09 July 2012 12:22 By: Ed Willink |
Apply a profile to UML model |
13436 |
Wed, 04 July 2012 06:52 By: Federico Toledo |
what about the messages in the list e.m.m2m |
7389 |
Thu, 28 June 2012 09:54 By: Ed Willink |
[ATL] how can I the filename of the source model? |
6547 |
Thu, 07 June 2012 16:55 By: Ed Willink |
Poll: ATL - if expression error |
6518 |
Thu, 24 May 2012 16:44 By: Fernanda R.F. |
Merging multiple Instance Models How to specify multiple instance models as input in ATL |
4298 |
Tue, 22 May 2012 10:24 By: Ed Willink |
VMException error when try to read part of a UML file VMException error is being shown when is tried to get some values from a UML sequence file |
6347 |
Mon, 07 May 2012 18:59 By: Fernanda R.F. |
[QVT tutorial] How can I debug (step into) script ? |
9619 |
Sun, 06 May 2012 02:58 By: Alain Lavoie |
Welcome to the new MMT newsgroup (formerly M2M) |
6938 |
Thu, 03 May 2012 20:16 By: Ed Willink |
