  This forum has been archived
By: Derek Toolan on Wed, 14 September 2016
0 3342 Wed, 14 September 2016 13:58
By: Derek Toolan
  Installing MOFscript using http://www.modelbased.net/mofscript/update/
By: Mr Buckethead on Fri, 13 June 2014
0 4060 Fri, 13 June 2014 13:09
By: Mr Buckethead
  Is This Project Dead?
Project Update path in missing
By: A Hoyle on Sat, 22 February 2014
1 1384 Mon, 07 April 2014 16:29
By: mind mixer
  Input parameters in a transformation
By: beaperez Mising name on Thu, 22 August 2013
1 2178 Mon, 02 September 2013 08:49
  call a java method from a transformation
By: beaperez Mising name on Fri, 23 August 2013
1 2325 Mon, 02 September 2013 08:45
0 1815 Fri, 23 August 2013 10:56
0 1880 Fri, 23 August 2013 10:53
0 3231 Fri, 23 August 2013 10:51
0 2265 Fri, 23 August 2013 10:51
  Project MofScript
By: Arnedo Ramon on Wed, 26 June 2013
1 1811 Sat, 29 June 2013 08:38
By: Aram Hovsepyan
  [Help] Problem with MOFscript installation
By: Rafael Priego on Fri, 07 December 2012
2 3209 Mon, 10 December 2012 16:58
By: Euler Marinho
  call transformation from Java API
By: yeliu on Thu, 11 March 2010
5 6947 Wed, 12 September 2012 14:56
By: Federico Toledo
  Setting 'type' on uml.Property
How to set 'type' on an uml.Property
By: Rafael Oliveira on Fri, 03 August 2012
0 3174 Fri, 03 August 2012 10:32
By: Rafael Oliveira
  Subpackages URI problem
By: Toñi Reina on Mon, 19 July 2010
1 8806 Thu, 01 March 2012 09:36
By: Atenea Missing name
  Problem running transformation in Java
By: pere b on Thu, 15 December 2011
0 3894 Thu, 15 December 2011 14:20
By: pere b
  Applying Stereotypes
How to apply Profiles and stereotypes
By: ramthor on Thu, 01 December 2011
0 3752 Thu, 01 December 2011 13:50
By: ramthor
  MOFScript called from Java API can only transform UML2 3.0.0?
By: yeliu on Mon, 29 March 2010
1 3907 Fri, 28 October 2011 18:28
By: Mohsen
  Call a Java Method from MOFScript transformation
MOFScript
By: Bea on Sun, 23 October 2011
1 3198 Fri, 28 October 2011 04:48
By: Mohsen
  Looking for a working example
By: Mohsen on Fri, 28 October 2011
0 3434 Fri, 28 October 2011 04:41
By: Mohsen
  Problem with creating instances
By: No real name on Thu, 11 November 2010
1 5717 Thu, 18 November 2010 09:44
By: Gøran K. Olsen
  Feature not found
By: Torbjørn Knutsen on Wed, 20 October 2010
2 4433 Thu, 04 November 2010 14:50
0 4327 Mon, 19 July 2010 18:43
By: Toñi Reina
  get external path of output
By: yeliu on Tue, 01 June 2010
1 4237 Mon, 21 June 2010 14:05
By: Gøran K. Olsen
1 3317 Mon, 21 June 2010 14:05
By: Gøran K. Olsen
  MOFScript installation on Ganymede
By: Mario Cervera on Tue, 08 June 2010
2 4902 Tue, 08 June 2010 17:56
By: Mario Cervera
0 3950 Tue, 08 June 2010 13:19
By: Mario Cervera
  output from java program
By: yeliu on Tue, 06 April 2010
9 6502 Mon, 19 April 2010 11:37
By: Gøran K. Olsen
1 3548 Mon, 12 April 2010 07:46
By: Gøran K. Olsen
0 4567 Mon, 29 March 2010 12:57
By: yeliu
  transform uml2 2.1.0
By: yeliu on Tue, 16 March 2010
2 3891 Fri, 19 March 2010 14:30
By: Gøran K. Olsen
2 3280 Fri, 19 March 2010 14:30
By: Gøran K. Olsen
5 5778 Mon, 15 March 2010 09:06
By: yeliu
By: yeliu on Fri, 05 March 2010
1 3013 Tue, 09 March 2010 20:35
By: Gøran K. Olsen
1 3870 Tue, 09 March 2010 20:35
By: Gøran K. Olsen
  MOFScript:generate output with the same filename as the source file
By: yeliu on Mon, 01 March 2010
15 8617 Fri, 05 March 2010 09:04
By: yeliu
1 3532 Tue, 02 March 2010 14:00
By: Gøran K. Olsen
  Find the Target for a message
By: Pablo on Thu, 04 February 2010
1 3046 Fri, 05 February 2010 17:01
By: Gøran K. Olsen
  [Help] How to change the local of generated files
By: Fabricio Pellegrini on Thu, 21 January 2010
1 3810 Fri, 05 February 2010 16:49
By: Gøran K. Olsen
1 3167 Fri, 05 February 2010 16:49
By: Gøran K. Olsen
1 3849 Fri, 05 February 2010 12:04
By: Gøran K. Olsen
  MOFScript and UML State machines
By: ASN on Mon, 02 November 2009
5 5919 Fri, 06 November 2009 16:54
By: ASN
1 4437 Thu, 05 November 2009 11:53
By: Gøran K. Olsen
  [MOFScript] Is there any way of configuring MOF Script to load metamodels from different paths?
By: Toñi Reina on Thu, 24 September 2009
6 6303 Fri, 09 October 2009 08:45
By: Gøran K. Olsen
0 3798 Thu, 24 September 2009 17:00
By: Toñi Reina
  MOFScript & Eclipse Galileo (III). Problems with log & console
By: Toñi Reina on Sat, 19 September 2009
2 4517 Tue, 22 September 2009 12:43
By: Gøran K. Olsen
0 3901 Sat, 19 September 2009 13:52
By: Toñi Reina
  MOFScript & Eclipse Galileo (II)
By: Toñi Reina on Fri, 18 September 2009
0 5066 Fri, 18 September 2009 23:19
By: Toñi Reina
0 3572 Fri, 18 September 2009 23:19
By: Toñi Reina
  [MOFScript] MOFScript and Eclipse Galileo
By: Toñi Reina on Tue, 25 August 2009
8 7266 Fri, 18 September 2009 22:35
By: Toñi Reina
0 3682 Tue, 25 August 2009 17:36
By: Toñi Reina
  Executing Problem with Java API
By: Bekir on Tue, 18 August 2009
3 5432 Wed, 19 August 2009 12:55
By: Bekir
1 2519 Wed, 19 August 2009 09:10
By: Gøran K. Olsen
  Contribution for MOFScript project
By: Nicolas on Thu, 07 May 2009
2 4838 Tue, 12 May 2009 15:24
By: Gøran K. Olsen
By: Eclipse User on Thu, 07 May 2009
0 3095 Thu, 07 May 2009 15:39
  Sequence of Transformation
By: Fabricio Pellegrini on Wed, 11 March 2009
8 5186 Mon, 23 March 2009 18:24
0 2879 Wed, 11 March 2009 13:41
  Invoke transformation from Ant
By: Ander on Fri, 13 February 2009
2 3772 Mon, 16 February 2009 14:21
By: Gøran K. Olsen
0 2611 Fri, 13 February 2009 13:45
By: Ander
  Strange problem with imports and input models
By: Adrian Noguero on Wed, 21 January 2009
0 2770 Wed, 21 January 2009 10:53
By: Adrian Noguero
0 4302 Wed, 21 January 2009 10:53
By: Adrian Noguero
  Bug located when calling a java class from a transformation
By: Adrian Noguero on Thu, 08 January 2009
14 6512 Mon, 19 January 2009 14:44
By: Adrian Noguero
0 2582 Thu, 08 January 2009 10:42
By: Adrian Noguero
  Recursive import?
By: No real name on Fri, 05 December 2008
4 4050 Fri, 05 December 2008 16:14
By: No real name
  Recursive import?
0 2579 Fri, 05 December 2008 01:46
By: No real name
  [MOFScript] Integration
By: Diego on Tue, 14 October 2008
10 5017 Wed, 12 November 2008 14:28
By: Gøran K. Olsen
0 2445 Tue, 14 October 2008 20:29
By: Diego
  MOFScript material
By: Gøran K. Olsen on Thu, 02 October 2008
0 2380 Thu, 02 October 2008 08:06
By: Gøran K. Olsen
  MOFScript material
0 4496 Thu, 02 October 2008 08:06
By: Gøran K. Olsen
  Re: list.remove(object) remove all the rest elements:
By: Gøran K. Olsen on Thu, 11 September 2008
0 2478 Thu, 11 September 2008 15:09
By: Gøran K. Olsen
0 4242 Thu, 11 September 2008 15:09
By: Gøran K. Olsen
  Welcome to eclipse.mofscript
By: Eclipse Webmaster on Wed, 10 September 2008
0 2478 Wed, 10 September 2008 04:01
0 4563 Wed, 10 September 2008 04:01
Current Time: Sun May 27 19:55:20 GMT 2018
Powered by FUDForum. Page generated in 0.01924 seconds
