| Extension org.eclipse.ui.views.properties.tabbed.propertyContributor [message #946612] |
Tue, 16 October 2012 10:39 |
Hi everyone,
i'm facing an issue after moving from eclipse ganymede to Juno.
Within my RCP i've declared an extension
org.eclipse.ui.views.properties.tabbed.propertyContributor where the
property overridableTabListContentProvider is set to true.
When i'm opening my EditorPart, the selection is empty, if i do not
select anything within the editor and i'm just closing it, i got a
NullPointerException.
I tracked it a little and found out that it is linked to the
overridableTabListContentProvider=true, in this case, the
OverridableTabListContentProvider is using a WOrkbencPart that hasn't
been inited because no Selection Event happened. If i set change the
property to its default value, the TabListContentProvider is an
Overridable one and everything works fine.
For the record, i'm using plugin used for managin the properties tab is
org.eclipse.ui.views.properties.tabbed_3.5.300.v20120523-1955
Is there something that i could to avoid the issue or is it a bug within
the OverridableTabListContentProvider initialization?
And here is the StackTrace generated.
org.eclipse.ui.internal.views.properties.tabbed.view.OverridableTabListContentProvider.init(OverridableTabListContentProvider.java:110)
org.eclipse.ui.internal.views.properties.tabbed.view.OverridableTabListContentProvider.inputChanged(OverridableTabListContentProvider.java:97)
org.eclipse.jface.viewers.ContentViewer.handleDispose(ContentViewer.java:171)
org.eclipse.jface.viewers.StructuredViewer.handleDispose(StructuredViewer.java:2328)
org.eclipse.jface.viewers.ContentViewer$2.widgetDisposed(ContentViewer.java:214)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:123)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Widget.release(Widget.java:808)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:446)
org.eclipse.ui.internal.views.properties.tabbed.view.TabbedPropertyComposite.dispose(TabbedPropertyComposite.java:191)
at org.eclipse.ui.part.PageBookView.removePage(PageBookView.java:856)
at org.eclipse.ui.part.PageBookView.partClosed(PageBookView.java:787)
org.eclipse.ui.views.properties.PropertySheet.partClosed(PropertySheet.java:287)
at org.eclipse.ui.part.PageBookView$4.partClosed(PageBookView.java:1047)
at org.eclipse.ui.internal.WorkbenchPage$18.run(WorkbenchPage.java:4398)
org.eclipse.ui.internal.WorkbenchPage.firePartClosed(WorkbenchPage.java:4396)
org.eclipse.ui.internal.e4.compatibility.CompatibilityPart$1.handleEvent(CompatibilityPart.java:99)
org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:57)
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setWidget(UIElementImpl.java:248)
org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.unbindWidget(SWTPartRenderer.java:114)
org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.disposeWidget(SWTPartRenderer.java:135)
org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.disposeWidget(ContributedPartRenderer.java:285)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:840)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$3(PartRenderingEngine.java:768)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$8.run(PartRenderingEngine.java:763)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.removeGui(PartRenderingEngine.java:748)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.handleEvent(PartRenderingEngine.java:144)
org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setToBeRendered(UIElementImpl.java:290)
org.eclipse.e4.ui.internal.workbench.PartServiceImpl.hidePart(PartServiceImpl.java:1094)
org.eclipse.e4.ui.internal.workbench.PartServiceImpl.hidePart(PartServiceImpl.java:1029)
org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.closePart(StackRenderer.java:1015)
org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.access$9(StackRenderer.java:997)
org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer$9.close(StackRenderer.java:890)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1810)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:275)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
FUDForum. Page generated in 0.01948 seconds
