Home » Language IDEs » Java Development Tools (JDT) » Re: Bug in "align fields in columns" Formatter with inline comments
Re: Bug in "align fields in columns" Formatter with inline comments [message #692908] Tue, 05 July 2011 13:00 Go to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Nemo,
I'm forwarding your question to the JDT newsgroup which should be a
better match.
Sebastian
On 05.07.11 14:26, NemoStein wrote:
> Hail community!
> I'm moving this thread from newcomers forums, as no one gave attention
> to it there.
> Sorry if this isn't the place (again).
> I think that my issue is a (rather simple) bug.
> When formating multiple fields with "align fields in columns" checked
> and with comments at the end of the line, depending on the number of
> characters in that line, the comment come one tab back.
> Assume the following code:
> public String ONE = "1"; // a
> public String TWO = "22"; // b
> public String THREE = "333"; // c
> public String FOUR = "4444"; // d
> When applying formatting, this is what I expect as formated output:
> But this is the formated output that I receive:
> if you increase or decrease in one the number of characters in the value
> part (the string itself) the formatting works like expected.
> public String TWO = "2"; // b
> public String TWO = "222"; // b
> Some one knows if this is a bug or a problem with my setup?
Bug in "align fields in columns" Formatter with inline comments [message #692967 is a reply to message #692908] Tue, 05 July 2011 15:01 Go to previous messageGo to next message
NemoStein  is currently offline NemoStein Friend
This is the original post, thank you Sebastian!
_______________________________________________
When formating multiple fields with "align fields in columns" checked and with comments at the end of the line, depending on the number of characters in that line, the comment come one tab back.
if you increase or decrease in one the number of characters in the value part (the string itself) the formatting works like expected.
Re: Bug in "align fields in columns" Formatter with inline comments [message #693376 is a reply to message #692967] Wed, 06 July 2011 11:06 Go to previous messageGo to next message
Satyam Kandula is currently offline Satyam KandulaFriend
Have you modified any formatter preferences? Using the default options, I am neither getting the code as you are expecting nor as you are getting.
Re: Bug in "align fields in columns" Formatter with inline comments [message #693391 is a reply to message #693376] Wed, 06 July 2011 11:30 Go to previous message
Sorry, I haven't seen the post properly. Please file a bug at https://bugs.eclipse.org/bugs/enter_bug.cgi?product=JDT;component=Core
Previous Topic:Eclipse Error
Next Topic:create a web service client from a WSDL that is only accessible via a self-signed SSL cert
Current Time: Fri Sep 01 05:11:41 GMT 2023
Powered by FUDForum. Page generated in 0.01486 seconds
