Home » Eclipse Projects » Libra » Unable to create OSGi Bundle faceted project
Unable to create OSGi Bundle faceted project [message #685747] Sun, 19 June 2011 08:05 Go to next message
Sahoo Missing name is currently offline Sahoo Missing nameFriend
I am using
"Eclipse Java EE IDE for Web Developers.
Version: Helios Service Release 1
Build id: 20100917-0705"
I installed libra plugin from p2 indigo repo. The complete list of featuresis given below:
Copyright Wizard 1.3.0 com.wdev91.eclipse.copyright.feature.feature.group
Eclipse IDE for Java EE Developers 1.3.1.20100916-1202 epp.package.jee
Maven Integration for Eclipse (Required) 0.12.1.20110112-1712 org.maven.ide.eclipse.feature.feature.group
Maven Integration for WTP (Optional) 0.11.1.20101108-1810 org.maven.ide.eclipse.wtp.feature.feature.group
OSGi Bundle Facet (Incubation) 0.1.0.201105161144 org.eclipse.libra.facet.feature.feature.group
Project configurators for commonly used maven plugins (temporary) 0.12.0.20101103-1500 org.maven.ide.eclipse.temporary.mojos.feature.feature.group
Tycho Project Configurators 0.4.3.20101103-1630 org.sonatype.tycho.m2e.feature.feature.group
WAR Products (Incubation) 0.1.0.201105161144 org.eclipse.libra.warproducts.feature.feature.group
I can't get the libra plugin to work at all. I tried two things:
a) Created a Dynamic Web Project and tried to convert it to a OSGi bundle faceted one by right clicking and using confgure menu, but nothing happened. I saw the following exception in log file:
!ENTRY org.eclipse.ui 4 0 2011-06-19 13:32:07.193
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/libra/facet/OSGiBundleFacetUtils
at org.eclipse.libra.facet.ui.popup.actions.ConvertProjectsToBundlesAction.getUnconvertedProjects(ConvertProjectsToBundlesAction.java:105)
at org.eclipse.libra.facet.ui.popup.actions.ConvertProjectsToBundlesAction.run(ConvertProjectsToBundlesAction.java:60)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3540)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3161)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Then I tried to add "OSGi bundle facet," using project properties menu, but got an NPE. Here is what I see in log file for this operation:
!ENTRY org.eclipse.wst.common.project.facet.core 4 0 2011-06-19 13:32:28.173
!MESSAGE Failed to load class "org.eclipse.libra.facet.OSGiBundleFacetInstallConfigFactory" from plugin "org.eclipse.libra.facet".
!STACK 0
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.libra.facet (769).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:121)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:453)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:469)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:338)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:232)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1197)
at org.eclipse.wst.common.project.facet.core.util.internal.PluginUtil.loadClass(PluginUtil.java:197)
at org.eclipse.wst.common.project.facet.core.util.internal.PluginUtil.instantiate(PluginUtil.java:250)
at org.eclipse.wst.common.project.facet.core.internal.ActionDefinition.createConfigObject(ActionDefinition.java:139)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProjectWorkingCopy.createProjectFacetAction(FacetedProjectWorkingCopy.java:1461)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProjectWorkingCopy.refreshProjectFacetActions(FacetedProjectWorkingCopy.java:1558)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProjectWorkingCopy.setProjectFacets(FacetedProjectWorkingCopy.java:777)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProjectWorkingCopy.addProjectFacet(FacetedProjectWorkingCopy.java:807)
at org.eclipse.wst.common.project.facet.ui.internal.FacetsSelectionPanel.handleCheckStateChanged(FacetsSelectionPanel.java:758)
at org.eclipse.wst.common.project.facet.ui.internal.FacetsSelectionPanel.access$10(FacetsSelectionPanel.java:729)
at org.eclipse.wst.common.project.facet.ui.internal.FacetsSelectionPanel$6.checkStateChanged(FacetsSelectionPanel.java:309)
at org.eclipse.jface.viewers.CheckboxTreeViewer$1.run(CheckboxTreeViewer.java:166)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.CheckboxTreeViewer.fireCheckStateChanged(CheckboxTreeViewer.java:164)
at org.eclipse.jface.viewers.CheckboxTreeViewer.handleSelect(CheckboxTreeViewer.java:300)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1220)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:228)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:222)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:389)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.wst.common.project.facet.ui.internal.FacetsSelectionDialog.openDialog(FacetsSelectionDialog.java:84)
at org.eclipse.wst.common.project.facet.ui.PresetSelectionPanel.handleModifyButtonPressed(PresetSelectionPanel.java:165)
at org.eclipse.wst.common.project.facet.ui.PresetSelectionPanel.access$0(PresetSelectionPanel.java:163)
at org.eclipse.wst.common.project.facet.ui.PresetSelectionPanel$1.widgetSelected(PresetSelectionPanel.java:96)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction.java:117)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.libra.facet.Activator.start() of bundle org.eclipse.libra.facet.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:284)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:417)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:265)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:106)
... 77 more
Caused by: java.lang.NoSuchMethodError: org.osgi.framework.BundleContext.getServiceReference(Ljava/lang/Class;)Lorg/osgi/framework/ServiceReference;
at org.eclipse.libra.facet.Activator.start(Activator.java:46)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
... 83 more
!ENTRY org.eclipse.jface 4 2 2011-06-19 13:32:28.182
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
at org.eclipse.wst.common.project.facet.core.internal.ActionDefinition.createConfigObject(ActionDefinition.java:142)
at org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDialogAction.java:157)
at org.eclipse.ui.internal.ide.actions.ProjectPropertyDialogAction.run(ProjectPropertyDialogAction.java:77)
What am I missing?
Sahoo
Re: Unable to create OSGi Bundle faceted project [message #685792 is a reply to message #685747] Mon, 20 June 2011 06:21 Go to previous messageGo to next message
Kaloyan Raev is currently offline Kaloyan RaevFriend
Hi Sahoo,
Thank you for trying out Libra.
I think the problem is that you have installed the OSGi Bundle Facet feature on a Helios IDE. The minimum Eclipse version supported is Indigo.
Please take one of of the Indigo RC4 packages, install Libra and try again:
http://www.eclipse.org/downloads/packages/release/indigo/RC4
I reported bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=349783 to prevent this feature installing successfully on Indigo.
Greetings,
Kaloyan
Re: Unable to create OSGi Bundle faceted project [message #697806 is a reply to message #685792] Mon, 18 July 2011 05:31 Go to previous messageGo to next message
I have just installed eclipse.javaee.indigo. Where do I get a compatible libra plugin? Thank you very much.
Re: Unable to create OSGi Bundle faceted project [message #697810 is a reply to message #697806] Mon, 18 July 2011 06:01 Go to previous messageGo to next message
Follow these instructions: http://wiki.eclipse.org/Libra/Getting_Started#Installation_and_Use
You need to select the OSGi Bundle Facet feature from the Indigo update site.
Re: Unable to create OSGi Bundle faceted project [message #698303 is a reply to message #697810] Tue, 19 July 2011 08:35 Go to previous messageGo to next message
Thanks, that got me going. I will create a new thread to provide some feedback.
Re: Unable to create OSGi Bundle faceted project [message #1763342 is a reply to message #698303] Fri, 12 May 2017 21:45 Go to previous message
Erika Bonilla is currently offline Erika BonillaFriend
Hi! I had a similar problem, I hope you can help me please!
When I see my localhost,log (after open Admin on tomcat) I get this error:
"jGRAVE: Excepción enviando evento inicializado de contexto a instancia de escuchador de clase com.actuate.birt.report.viewer.ContextInitListener
java.lang.NoSuchMethodError: com.actuate.birt.report.viewer.Activator.getBundle()Lorg/osgi/framework/Bundle;
at com.actuate.birt.report.viewer.ContextInitListener.contextInitialized(ContextInitListener.java:75)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4994)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5492)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:649)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1247)
at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1897)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:748)"
Previous Topic:WAR Products - UI problems since Eclipse Neon IDE M6
Current Time: Wed Jul 12 03:32:27 GMT 2017
Powered by FUDForum. Page generated in 0.03670 seconds
