| How to extend a new service to Tcf,like windriver gopher? [message #1748227] |
Mon, 21 November 2016 12:11  |
tian dan Messages: 4 Registered: August 2014 |
Junior Member |
Hi!
I want to extend Tcf and a new service,like windriver gopher.
Adn I has some idea,modify the demo "daytime"
1, ,add gopher interpreter code to agent, and buid it;
2, create a plugin, add extend tcf service to sent gopher string
3, run it
Is it OK? or their is another way? Thanks ver much!
| Re: How to extend a new service to Tcf,like windriver gopher? [message #1750271 is a reply to message #1748383] |
Mon, 19 December 2016 12:27   |
Junior Member |
Thanks for ur Reply.
Our IDE uses GDB for embeded debug now,and we planed to use TCF instead of it.But My RTOS does not have a file system.
So I have an idea that we imply a net FS by extend TCF:
1. On Host TCF plugins, create a new class Called FileSystemService,which inherited FileSystemProxy, register
to ServiceManager----and will override existing FileSystemProxy, to deal with Target Commands.The Host looks
like a FS "Target" Peer,receiving Target FS Commmand Message,and do it on the aimed local filesystem.
2. The target TCF agent create a FS library, take the FS interface as TCF command message and sent it to Host. The
Target looks like a FS "Host" Peer,sending FS command message to Host.
3. TCF Agent's Services which need FS Service like symbolService can use the aboved FS service.
Can This works well?and the efficiency?
Thank you!
[Updated on: Mon, 19 December 2016 13:08] Report message to a moderator
FUDForum. Page generated in 0.03196 seconds
