| [RAP] Font.equals with disposed fonts [message #1699915] |
Mon, 29 June 2015 09:09 |
Jerome Sivadier Messages: 15 Registered: May 2015 |
Junior Member |
Dear SWT community,
I'm currently using SWT and draw2d for RAP and I'm not sure if I should post here or in the RAP forum. My problem is located in the jars "org.eclipse.rap.rwt_2.3.2.20150128-1013.jar" and "org.eclipse.rap.draw2d_0.1.0.20141203-1509.jar".
Actually in my RAP application, the layout managers are calling FlowUtilities#getAverageCharWidth with a "Font {Arial,10,NORMAL}". Then this method calls FigureUtilities#getFontMetrics with that same font, and this last method calls its internal #setFont to change the current FigureUtilities cached font.
The problem is that internally FigureUtilities has another Font stored with the exact same FontData: "Font {Arial,10,NORMAL}" but this font is DISPOSED. Indeed when the method setFont is called, the fonts are compared and both are qualified EQUALS because the Font#equals method does not check if the Font is disposed...
Is this a normal behavior? Should the equals method return false when a Font is disposed and the other not, but they have the exact same FontData? Should I never encounter this behavior?
Thanks for any answer.
Jerome.
EDIT: I've just fixed in my local instance the problem by doing a checkout on "org.eclipse.rap.draw2d" and modifying the "FigureUtilities#setFont" to check for disposed Fonts. It works as expected. Indeed I guess it's not a SWT bug but a RCP Draw2d bug so if a moderator could move my message into the right forum (RAP / Incubator) it would be appreciated .
@SEE: https://bugs.eclipse.org/bugs/show_bug.cgi?id=471341
[Updated on: Mon, 29 June 2015 15:30] Report message to a moderator
FUDForum. Page generated in 0.01859 seconds
