Eclipse Community ForumsCannot create a new branch
https://www.eclipse.org/forums/index.php/mv/msg/9780/29996/#msg_29996
following error:
Branch operation for some of selected resources failed.
A path under version control is needed for this operation
I can commit, update, and view history, so I know the project is under
version control. Branching worked fine in 0.7.1]]>Jonathan Marston2008-08-05T16:52:26-00:00Re: Cannot create a new branch
https://www.eclipse.org/forums/index.php/mv/msg/9780/30097/#msg_30097
Originally posted by: alexander.gurov.polarion.org
Hello Jonathan,
The issue is related to the native JavaHL binaries of 1.5.1 version. In
order to avoid the problem you can use SVN Kit 1.2.0-based connector
instead of Native JavaHL-based one. The fix for described problem will be
available in the weekly build (I've returned 1.5.0 native binaries back).]]>2008-08-06T09:51:59-00:00
