Eclipse Community ForumsCustomize Editing Tables...
https://www.eclipse.org/forums/index.php/mv/msg/945880/1565829/#msg_1565829
Here are the 2 questions
Is there any possibility to customize style of Header labels (Bold, Color, etc..) in a Feature Column ?
Is it possible to display a combox for representing a boolean instead of a checkbox(which is the default) in an Edition Table?
Franck ]]>Franck MIMET2015-01-15T14:08:31-00:00Re: Customize Editing Tables...
https://www.eclipse.org/forums/index.php/mv/msg/945880/1567251/#msg_1567251
styles which includes color, label style to customize.
Best Regards.
Le 15/01/2015 15:08, Franck MIMET a écrit :
> Hello,
> Here are the 2 questions :roll: Is there any possibility to customize
> Regards,
> Franck
Esteban Dugueperoux - Obeo
Need professional services for Sirius? http://www.obeodesigner.com/sirius]]>Esteban Dugueperoux2015-01-16T08:35:38-00:00Re: Customize Editing Tables...
https://www.eclipse.org/forums/index.php/mv/msg/945880/1567304/#msg_1567304
I agree, but as far as I understood, it does not concern the Header.
Franck]]>Franck MIMET2015-01-16T09:19:22-00:00Re: Customize Editing Tables...
https://www.eclipse.org/forums/index.php/mv/msg/945880/1619540/#msg_1619540
> Hello,
The Header labels cannot be customized from the VSM editor.
Sirius will display a checkbox for boolean typed attribute, if you add a
direct edit tool, you will have a text cell editor. There is no current
way to get a combo box for a boolean (except if you metamodel defines it
own data type whose name is different from Boolean or EBoolean).
