Eclipse Community Forums[Fwd: [MetaModel] Why do not use BPDM as MetaModel ?]
https://www.eclipse.org/forums/index.php/mv/msg/8434/25935/#msg_25935
Originally posted by: emmanuel.rias.bull.net
--------------050503020903060902010306
Content-Type: message/rfc822;
name="[MetaModel] Why do not use BPDM as MetaModel ?"
Content-Disposition: inline;
filename="[MetaModel] Why do not use BPDM as MetaModel ?"
BPDM (Business Process Definition MetaModel) project has started few
years ago. The goal of this project is:
"This specification has been through a multi-year process within the
Object Management Group (OMG) to define a common meta model for the
various process notations, methodologies and standards. BPDM also
serves as the meta model behind the popular Business Process Modeling
(BPMN) notation."
The last proposal for specification has been submited at the end of last
month. You can visit the site http://www.modeldriven.org/web/bpdm and
see the specification.
I see a lot of advantages:
1) A lot of people have worked on this model and i think they fixed a
lot of potential problems
2) This is linked with the BPMN project, the standard in terms of GUI
approach
3) This is the OMG standard meta model
4) It covered XPDL and BPEL
So what do you think ?
Emmanuel
--------------050503020903060902010306--]]>2007-04-16T14:35:40-00:00Re: [Fwd: [MetaModel] Why do not use BPDM as MetaModel ?]
https://www.eclipse.org/forums/index.php/mv/msg/8434/25976/#msg_25976
I agree with you that BPDM is a great meta-model that captures all the
aspects that we will need. But it is much too big when you want to
implement all aspects in a few month. Using BPDM would take us years to
come up with a presentable solution. Therefore, I agree with Marc in one
of his former posts, where he said that we should more focus on existing
tools and how they can be changed in order to meet all requirements for
XPDL, BPEL, etc. than to start from scratch and throw away all existing
code.
The work from Steve is a great starting point and gives us hints what we
will need to change on the current meta-model in order to generate XPDL in
the end.
