Eclipse Community Forums[Acceleo] XMLResource: EReference with kind=element broken
https://www.eclipse.org/forums/index.php/mv/msg/818739/1431082/#msg_1431082
made a small metamodel with Root, Person, Team classes. Team references its members as non-containment EReference to person.
Choose XML as resource. Without further changes everything is generated fine and acceleo can process the generated model instances.
Made a duplicate metamodel, but decorated all attributes and references of Person and Team with ExtendedMetaData "kind=element", as I want an element-based XML serialization.
Generation runs fine, EMF model, edit, editor work fine as well.
Acceleo fails to follow the EReferences from team objects to person objects.
Tested with vanilla Kepler and Luna.
I guess that is a bug, isn't it?
What would be needed for bugzilla? "ecore", "genmodel", model and "mtl" files?
Best Regards
Uwe ]]>Uwe Ritzmann2014-09-25T07:16:32-00:00Re: [Acceleo] XMLResource: EReference with kind=element broken
https://www.eclipse.org/forums/index.php/mv/msg/818739/1435379/#msg_1435379
Does the duplicate metamodel have a different nsUri?
