Eclipse Community ForumsCreate Customise Views for Merging
https://www.eclipse.org/forums/index.php/mv/msg/818157/1430415/#msg_1430415
I am developing an RCP application and I want to add SVN support to the files the user will generate (the application is more or less an editor). I'd like to know if its possible to extend the merging dialog for adding/removing possible actions.
I need that the user chooses between overwrite a single change/ overwrite all changes/ keep a single difference or keep all differences as a radio-button set in the default merging dialog.
I suppose I need to extend the dialog via the MANIFEST. Can you point me in the right direction?
Thanks in advance]]>Nieves Salor2014-09-24T10:53:32-00:00Re: Create Customise Views for Merging
https://www.eclipse.org/forums/index.php/mv/msg/818157/1439010/#msg_1439010
Unfortunately there is no such API at the moment. We will be glad to hear your suggestions and see if there is something we could do to improve your experience with Subversive.
Thank you in advance.]]>Alexander Gurov2014-10-06T19:46:18-00:00
