Eclipse Community ForumsHow do I check a Function for Syntax Errors
https://www.eclipse.org/forums/index.php/mv/msg/806308/1417133/#msg_1417133
However, I would like to use LDT to check a function for syntax errors. I believe that syntax errors should be indicated by error markers? How can I make LTD find these errors?
I put the cursor on one of the function definitions and tried "Run" and also "Debug", but none of these worked.]]>Erik Viking2014-05-21T20:56:36-00:00Re: How do I check a Function for Syntax Errors
https://www.eclipse.org/forums/index.php/mv/msg/806308/1417135/#msg_1417135
Simon Bernard2014-05-22T09:29:34-00:00
