Eclipse Community ForumsNo application id has been found.
https://www.eclipse.org/forums/index.php/mv/msg/792/2071/#msg_2071
Originally posted by: wakim5000e.yahoo.de
The Version: 0.7.0.20080517 | Date: 17 May 2008 | Type: Nightly Build for
Win32 is not working. The following message appears in the log file:
!ENTRY org.eclipse.osgi 4 0 2008-05-28 10:04:55.735
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:234)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.start(E clipseAppContainer.java:96)
at
org.eclipse.equinox.internal.app.Activator.addingService(Act ivator.java:127)
at
org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTracker.java:1064)
at
org.osgi.util.tracker.ServiceTracker$Tracked.trackInitialSer vices(ServiceTracker.java:926)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:330)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:274)
at org.eclipse.equinox.internal.app.Activator.start(Activator.j ava:56)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:419)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:354)
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:427)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:383)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:371)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
org.eclipse.core.internal.runtime.PlatformActivator.startApp Container(PlatformActivator.java:47)
at
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:32)
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1073)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:632)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:506)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:280)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:466)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:209)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:319)]]>2008-05-28T08:23:11-00:00Re: No application id has been found.
https://www.eclipse.org/forums/index.php/mv/msg/792/2087/#msg_2087
the Memory Analyzer needs JDK5
> java.version=1.4.2_15
Kind regards,
- Andreas.]]>Andreas Buchen2008-05-28T11:42:49-00:00Re: No application id has been found.
https://www.eclipse.org/forums/index.php/mv/msg/792/2101/#msg_2101
MemoryAnalyzer.exe -vm <path to 1.5er vm>]]>Andreas Buchen2008-05-28T11:51:32-00:00
