!ENTRY org.eclipse.osgi 2 0 2014-05-26 09:52:16.422 !MESSAGE AccTestje.main.Generate cannot be found by AccTestje_1.0.0.qualifier !STACK 0 java.lang.ClassNotFoundException: AccTestje.main.Generate cannot be found by AccTestje_1.0.0.qualifier at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160) at java.lang.ClassLoader.loadClass(ClassLoader.java:356) at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:568) at org.eclipse.acceleo.common.internal.utils.workspace.AcceleoWorkspaceUtil.getClass(AcceleoWorkspaceUtil.java:544) at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoLaunchOperation.run(AcceleoLaunchOperation.java:103) at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2313) at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2295) at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginLaunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java:259) at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginLaunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java:161) at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchDelegate.launch(AcceleoLaunchDelegate.java:51) at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:884) at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739) at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039) at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.acceleo.common 2 0 2014-05-26 09:52:16.425 !MESSAGE Couldn't load class AccTestje.main.Generate. Check that its containing package is exported. !ENTRY org.eclipse.acceleo.ide.ui 4 0 2014-05-26 09:52:16.562 !MESSAGE Couldn't load class AccTestje.main.Generate from project AccTestje
Manifest-Version: 1.0 Bundle-ManifestVersion: 2 Bundle-Name: Acceleo AccTestje Module Runtime Plug-in Bundle-SymbolicName: AccTestje Bundle-Version: 1.0.0.qualifier Bundle-Activator: AccTestje.Activator Bundle-Vendor: Eclipse Modeling Project Require-Bundle: org.eclipse.core.runtime, org.eclipse.uml2.uml, org.eclipse.emf.ecore, org.eclipse.emf.ecore.xmi, org.eclipse.ocl, org.eclipse.ocl.ecore, org.eclipse.acceleo.common;bundle-version="3.3.0", org.eclipse.acceleo.model;bundle-version="3.3.0", org.eclipse.acceleo.profiler;bundle-version="3.3.0", org.eclipse.acceleo.engine;bundle-version="3.3.0", com.google.guava Bundle-RequiredExecutionEnvironment: JavaSE-1.7 Bundle-ActivationPolicy: lazy Eclipse-LazyStart: true Export-Package: AccTestje.main
[comment encoding = UTF-8 /] [module generate('http://www.eclipse.org/uml2/5.0.0/UML')] [template public generateElement(aModel : Model)] [comment @main/] [file (aModel.name, false, 'UTF-8')] This is generated. [/file] [/template]
