Eclipse Community Forums[EMFTVM] What metametamodel I can use?
https://www.eclipse.org/forums/index.php/mv/msg/770648/1373373/#msg_1373373
I did not find any restrictions on metametamodel to use with EMFTVM. Should it be strictly ECORE? Can I extend ECORE?
Let say I built metametamodel myMMModel where I introduced myPackage as successor of EPackage, myElement and myComponent as successors of EClass etc. Then, using myMMModel, I built metamodel myMModel where package is of type myPackage, classes are of type either myElement or myComponent etc. Can I use EMFTVM to transform from myMModel metamodel to other metamodels and vice versa? And what precautions I should follow?
]]>Maxim Gromov2014-05-22T06:24:24-00:00Re: [EMFTVM] What metametamodel I can use?
https://www.eclipse.org/forums/index.php/mv/msg/770648/1374743/#msg_1374743
The scenario of extending Ecore as meta-metamodel has never been considered
for EMFTVM. I don't think this works yet, but it may be fairly easy to
implement. You may report it as a feature request on Bugzilla, and provide an
example meta-metamodel to test against.]]>Dennis Wagelaar2014-05-22T19:43:10-00:00
