Eclipse Community ForumsView Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1341568/#msg_1341568
When I select Run -> View Report -> In Web Viewer I get the following error message:
HTTP ERROR: 500
Problem accessing /viewer/frameset. Reason:
Server Error
Powered by Jetty://
How can I fix this?
]]>Harry Mantheakis2014-05-08T14:48:15-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1375661/#msg_1375661
Michael Williams2014-05-23T04:58:20-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1376599/#msg_1376599
Harry Mantheakis2014-05-23T13:44:11-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1384491/#msg_1384491
http://blogs.actuate.com/using-birt-viewer-toolkit-as-the-default-viewer/]]>Michael Williams2014-05-29T05:38:58-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1384557/#msg_1384557
Setting up BIRT Viewer to work with a local instance of (say) Tomcat, using a workspace that Tomcat can access, etc., is not quite the simple solution I was hoping for.
We do use BIRT Viewer to render our reports in our application - and we use the Ant "sync" task to update reports (from an Eclipse workspace to a Tomcat webapps context) during development, which is a good workaround for when a BIRT report is already wired into an application that can (in turn) be used to invoke the report. (You do not even have to re-start Tomcat to see the changes, which is cool.)
What I was hoping for was a standalone solution whereby a developer does not need to be running Tomcat (or any other Servlet container) with BIRT Viewer deployed, etc.
I am sure that at one time the BIRT Viewer feature worked out-of-the-box, but I could be wrong about that.
]]>Harry Mantheakis2014-05-29T09:57:47-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1384639/#msg_1384639
Michael Williams2014-05-29T19:53:04-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1384683/#msg_1384683
What is more, with Java 7 the "Preview" function now fails - nothing is displayed.
I had the "Preview" function working with Java 8 after setting the following two properties in the "eclipse.ini" file:
]]>Harry Mantheakis2014-05-30T10:54:28-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1385219/#msg_1385219
Michael Williams2014-06-05T04:20:19-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1385315/#msg_1385315
The problem I have is with Eclipse running on its own.
It should be possible to select "Run -> View Report -> In Web Viewer" and see a BIRT Viewer rendition of the report currently open in Eclipse.
I seem to recall that - a good while back - this used to work .
With Java 7 it *almost* works - the BIRT Viewer "window" (header, buttons, etc.) renders, but the report fails to display.
Am I correct in thinking that selecting "Run -> View Report -> In Web Viewer" should display my report - with Eclipse running on its own, and default settings?
]]>Harry Mantheakis2014-06-05T15:01:05-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1385317/#msg_1385317
Yes, you should be able to run the web viewer using the method you say above. You'll probably need to go to the Preferences -> Report Design -> Preview and select to use external browser for it to work properly with Java 7. Let me know.]]>Michael Williams2014-06-05T15:08:05-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1385337/#msg_1385337
When I tried this with Java 8, I get the same error message as I originally posted:
HTTP ERROR: 500
Server Error
Powered by Jetty://
So I guess it is back to Java 7 for us
]]>Harry Mantheakis2014-06-05T17:20:43-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1385347/#msg_1385347
Michael Williams2014-06-05T18:17:57-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1410416/#msg_1410416
We have gone ahead and created a Bugzilla for this issue: https://bugs.eclipse.org/bugs/show_bug.cgi?id=435395
I would appreciate it if you can summarize this forum thread with your findings into the Bugzilla. You may also want to add yourself as a "cc" so you can keep posted on the activity over on the bugzilla.
Paul.
BIRT PMC]]>Paul Clenahan2014-08-20T18:23:45-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1410418/#msg_1410418
If you could review the Bugzilla and make sure it is up to date with the findings from this thread, that would be appreciated.
Thanks.
Paul.]]>Paul Clenahan2014-08-20T18:26:59-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1700355/#msg_1700355
This is Rajat...
I also faced this problem and got a resolved it by below steps :
1) Lower down your browser setting by going in to "internet option" in 'Security'
lower down the level of 'internet' and 'trusted sites' to medium/low.
2) In eclipse go into 'Windows' - > 'Perferences' -> 'Report Design' - > 'Preview' - > 'Preview Server' and type 'localhost' in first tab (Host name) and click apply.
Please try this...
It got working for me... ]]>Rajat Khedekar2015-07-02T07:07:30-00:00Re: View Report in Web Viewer Error
https://www.eclipse.org/forums/index.php/mv/msg/739682/1700382/#msg_1700382
also
Go to Eclipse - > Windows - > Preferences - > Report Design - >Preview - >Preview Server and type 'localhost' in first tab (host name)
or
else install latest internet explorer 11]]>Rajat Khedekar2015-07-02T09:49:33-00:00
