Eclipse Community ForumsTreeViewer with non-visible objects
https://www.eclipse.org/forums/index.php/mv/msg/73671/230273/#msg_230273
Originally posted by: johan.piculell.ericsson.com
Hi.
I have a ContentOutlinePage with a TreeView and this shows my graphical
objects I have in my model just fine, so far so good.
But now I want to add nodes in the TreeView that does not show in the
Editor area, i.e I have model objects that have no graphical
representation and should only show up in the tree overview.
I have not found any way to directly add nodes to the tree, so I tried to
add nodes just as I do with the graphical elements, but then I need to add
something to the editor area as well which messes up some other things
like autolayout.
Quite hard to explain, but someone hopefully follows what I mean and might
have a clue if this is possible to achieve or not.
regards
/Johan]]>2007-02-08T09:59:41-00:00Re: TreeViewer with non-visible objects
https://www.eclipse.org/forums/index.php/mv/msg/73671/230312/#msg_230312
Originally posted by: neerajkarandikar.gmail.com
I faced similer problem with no obvious and effiecient solution.
The workaround i used is:
For the components which should not be visible on graphical editor i added
an empty white image for the graphical editor and placed them at 0,0
location then i made them non-selectable by user... I works fine but still
not very promising solution.
-Neeraj
"Johan" <johan.piculell@ericsson.com> wrote in message
news:07ee5407a89f47f4e1e7c894d2955f08$1@www.eclipse.org...
> Hi.
> objects I have in my model just fine, so far so good. But now I want to
> add nodes in the TreeView that does not show in the Editor area, i.e I
> have model objects that have no graphical representation and should only
> show up in the tree overview. I have not found any way to directly add
> nodes to the tree, so I tried to add nodes just as I do with the graphical
> elements, but then I need to add something to the editor area as well
> which messes up some other things like autolayout. Quite hard to explain,
> but someone hopefully follows what I mean and might have a clue if this is
> regards
> /Johan
>]]>2007-02-08T11:21:29-00:00Re: TreeViewer with non-visible objects
https://www.eclipse.org/forums/index.php/mv/msg/73671/230498/#msg_230498
Originally posted by: none.unknown.com
There is no restriction saying that you can only have tree items for items
in the editor. You don't need to add anything to the editor. The tree
editpart can return a different set of children in its getModelChildren()
method than the one in the editor.
"neeraj" <neerajkarandikar@gmail.com> wrote in message
news:eqf13t$eao$1@utils.eclipse.org...
> -Neeraj
>> Hi.
>> graphical elements, but then I need to add something to the editor area
>> as well which messes up some other things like autolayout. Quite hard to
>> explain, but someone hopefully follows what I mean and might have a clue
>> regards
>> /Johan
>]]>2007-02-13T00:18:47-00:00
